morlex13
Link Posted: Thu Sep 11, 2008 9:26 pm Post subject: help sync rtc 2220 |
hi,i have a little problem wiht my new rtc 2220
if i plug nvidia geforce 7800 to the rtc input>>rtc output>monitor lcd ,no problem,it's works fine
if i plug nvidia 8200 integrated video chip on mother board(asus m3n78-emh hdmi) to rtc input>barco 808 port 3 to rtc output:no signal
anyone have an idea?
thanks
manu
beun
Link Posted: Thu Sep 11, 2008 11:16 pm Post subject: Re: help sync rtc 2220 |
morlex13 wrote: | hi,i have a little problem wiht my new rtc 2220
thanks
manu |
Internal video may be turned off in the bios.
morlex13
Link Posted: Fri Sep 12, 2008 5:15 am Post subject: |
beun wrote: | Are you sure the integrated video chip actually has an analog RGB signal on it?
Kim |
yes i am sure
the video ship have two output,one hdmi and one vga..
the barco work fine with vga chip output is pluged on port 3...
Rolls-Royce
Link Posted: Fri Sep 12, 2008 4:06 pm Post subject: |
Many times the integrated video chips don't offer the same resolutions as the stand-alone video cards. Yours may not be sending a resolution that the Barco can accept. Check your computer or mobo's documentation and/or nvidia's website for the resolutions and scanrates supported by the chipset. You may also want to try Powerstrip to see if it can set custom resolutions with the integrated chipset.
beun
Link Posted: Fri Sep 12, 2008 4:21 pm Post subject: |
If the onboard VGA definately has RGB on it there a two possibilities left (since the RTC2200 appears to work)
1) The H and V sync amplitude of the onboard VGA is not high enough (very unlikely) for the RTC2200 to recognize it (there is no quick fix for this)
2) The H sync of the onboard VGA is much narrower than the sync of the video card. To fix this, open the RTC2200 case and move the jumper from JP5 to JP6.
Kim
