morlex13
Link Posted: Tue Aug 26, 2008 6:48 am Post subject: rtc2200+hdfuryII |
hi
i would like to buy rtc2200
but,berfore y want to knoy if
rtc2200 work fine whit the future hdfury2??
thank you
Joined: 06 Mar 2006 Posts: 16751 Location: Ottawa, Canada
morlex13
Link Posted: Wed Aug 27, 2008 6:34 am Post subject: |
thanks
yes
i want to plug my pc by hdmi cable>hdfury2>rtc2200>barco port 3
is right?
fearn48
Joined: 07 May 2008 Posts: 26 Location: Reading, England
Link Posted: Thu Sep 18, 2008 2:36 pm Post subject: |
Hi Kal,
Could you confirm that the RTC2200 will add gamer boost to the output, when fed with a 1080/72p signal from the HDfury2?
I realise the Component conversion will not handle this refresh rate (tops out at 60p), and the RGB "pass-through " goes further (1600x1200/75Hz). However that is a computer resolution and they sometimes don't resolve every interim step.
Peter
_________________ If only you could see what I've seen with your eyes!
Link Posted: Thu Sep 18, 2008 5:32 pm Post subject: |
Hi Peter,
The HDfury2 does not support 1080p/72 output. It tops out at 1080p/60. There was a day or two when the specs said it could do 1080p/72 but that's still being testing thoroughly to make sure it can indeed do it, so for the time being that spec was removed from the order page (www.curtpalme.com/HDfury2.shtm) just to make sure there isn't any confusion.
Kim of Crescendo-Systems can chime in to confirm but it's my understanding that the RTC2200 will handle any and all resolution/refresh rate combos up to and including 1600x1200/75 through the RGB passthrough. Mine has certainly handled everything I throw at it.
Moot point if the HDfury2 doesn't do it however. Moome's EXT-FULLHD HDMI converter does handle 1080p/72 though. See: http://www.curtpalme.com/EXT-FULLHD.shtm
beun
Malakay
Link Posted: Thu Jun 23, 2011 1:16 pm Post subject: |
beun wrote: | Peter,
As kal mentioned, the RTC2200 will indeed do 1080p/72 through the RGB input without any problem. |
Sorry for reanimating this old thread, but i want to use the RTC2200 with 1080/72 and 75p. Is this possbile?
My chain will be:
BluRay/HD-DvD/DvD/Pal TV to Lumagen Radiance +(72/75Hz) - Fury3 - RTC2200 - CRT
Thanks for you help!
Best regards
Chris
beun
Malakay
Link Posted: Thu Jun 23, 2011 10:53 pm Post subject: |
I already bought the RTC2200 a few years ago from here. So im lucky with it in the past and im happy that i can use it also in the future.
Thanks for your answer.
gn8
Chris
