Observe, and weep:
PostLink    Posted: Mon Jun 16, 2008 4:04 am    Post subject: Observe, and weep: Reply with quote
PeriSoft's HT audio flowchart.
Total est. clean RMS wattage: 850
Acquisition cost, last 12 months: $200
Acquisition cost, including HTPC, total: $450
PostLink    Posted: Mon Jun 16, 2008 5:30 am    Post subject: Reply with quote
Wow now that's thrifty. Damed funny too
drice1234
PostLink    Posted: Mon Jun 16, 2008 11:45 am    Post subject: Reply with quote
And you can heat your house with all of that equipment.
PostLink    Posted: Mon Jun 16, 2008 1:51 pm    Post subject: Reply with quote
Dave will love the "Piracy Machine" comment. Wink
papalek
PostLink    Posted: Mon Jun 16, 2008 2:30 pm    Post subject: Reply with quote
I doubt that he has that much of a heat issue.
But I know I sure put off quite a bit.
2-Carver TFM15
3-Carver TFM35
2-Carver PM1.5
2-Crown CSL1400
It gets rather warm behind the curtain when the movie is rockin. Mr. Green Thumbs Up
I do love my AmPro's
PostLink    Posted: Mon Jun 16, 2008 4:09 pm    Post subject: Reply with quote
I'm gonne have all that stuff jammed into a closet as wide as a rack and only 2.5x as deep, so I've gotta be careful with heat. Planning on putting a big sucker on top and a vent to under the floor on the bottom to try to keep stuff cool.
greg_mitch
PostLink    Posted: Tue Jun 17, 2008 1:02 am    Post subject: Reply with quote
So you are using 4 receivers?! Surely there is a better way?
Hopefully you aren't buying these and are just scrapping a system together with left over parts! Razz
PostLink    Posted: Tue Jun 17, 2008 9:12 pm    Post subject: Reply with quote
The only one I bought was the technics for the mains, and that was about six years ago or so. OK, technically I bought the Onkyo, but it was 30 bucks at the Salvation Army.
One main issue is that I'm driving the fronts at 4ohms, and the amp won't do 5 channel output set up that way.
I could use the technics for all five channels, and sacrifice quality / power on the mains, but I'd have to use the optical input (no RCA digital) which would mean a $40 optical cable and a new sound card. As you may be able to guess, that expenditure would be difficult for me. Smile
This way I have some level of control over bass/treble for the center/surround, and in particular I have 16-band stereo EQ on the mains, separate from the rest.
If AC3 filter had parametric EQ per-channel there'd be less reason to do this, but there's also no guarantee that I'll have that option with a BR player when the time comes - and there's still the issue of the low impedance output for the mains.
I might be wrong about some of this stuff, though, so I'd welcome corrections and information if that's the case!
PostLink    Posted: Tue Jun 17, 2008 9:48 pm    Post subject: Reply with quote
Peri,
Do you have any pictures of the rack that you'll be using to house the recievers, I'm doing something similar however I'm only using three recievers.
PostLink    Posted: Wed Jun 18, 2008 3:09 am    Post subject: Reply with quote
Zebu Fellenz wrote:
Peri,
In true PeriSoft style, I'm doing it the nutter way. In this case, that means two of those vertical closet shelf rails - with the little vertical slats, that you hook shelfy-holder things to. All I'm doing is putting the holders on them and putting the kit right on the holders; no actual shelves. They can't go side to side because their feet match up with the width of the shelf holders (and because the closet is only a couple inches wider than the gear) and can't move forward because of the little lip on the front of the shelf holders.
I figure that the less solid surfaces, the more airflow; I haven't got each thing jammed in a little box. It also looks cool, because the shelf things are black, and the whole closet has black fabric, so it looks like the components are just hovering there. Thumbs Up
greg_mitch
PostLink    Posted: Fri Jun 20, 2008 2:37 am    Post subject: Reply with quote
Optical cables don't cost $40...more like $3.27! http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022901&p_id=1419&seq=1&format=2.
I still think it would be easier to just sell all of this stuff and buy one decent receiver, but this might look cooler. I don't even want to see a remote table for all of this stuff...or even better, the macros to control all of this with one remote!
Go for it!
PostLink    Posted: Fri Jun 20, 2008 9:45 am    Post subject: Reply with quote
Go for it!
I stand corrected on the cable... Smile but, even if I sold all of those, I'd only make about 150, and 140 of that from the technics! Smile the others are ancient. And of course no remotes - that's why I need the pirac... Htpc. Smile
Still haven't worked out a dirt cheap remote control system for it, though. Not line of sight.
aspec2
TV/Projector: Maquee 8500
PostLink    Posted: Fri Jun 20, 2008 5:02 pm    Post subject: Reply with quote
There was a large thread on the A site about using an HTPC for audio. I thought about using several mono blocks controlled by the HTPC as a preamp/receiver. It can ALL be controlled with one remote.
Walt
PostLink    Posted: Fri Jun 20, 2008 5:04 pm    Post subject: Reply with quote
Walt
I actually tried that once. I have 3 Marantz Ma-700's and 2 MA-500's. The bigest problem I had was on start up. The damned audio would tick and pop and make the speakers overload. Too loud. It was a good plan. I wonder if there's a card for the PC that doesn't do that when it's driver get's loaded in wondows?
nettwerkjohn
PostLink    Posted: Sat Jun 21, 2008 8:45 pm    Post subject: Reply with quote
whats windoze?
Angus_rg
PostLink    Posted: Sun Jun 22, 2008 1:46 am    Post subject: Reply with quote
Did the trickle and pop happen when the lame MS bootup music came on? You can go into your sound menu and disable that.
It's good to be the king.
PostLink    Posted: Sun Jun 22, 2008 5:29 am    Post subject: Reply with quote
Nope that was disabled. It was probably when Winblows loads the sound driver.
PostLink    Posted: Sun Jun 22, 2008 5:10 pm    Post subject: Reply with quote
I don't plan on turning the HTPC off, so not a big issue there. I didn't notice the problem anyway when I -did- have to power cycle with the amps on.
The one thing I really severely dislike is that AC3filter won't do per-channel EQ. I could get the system near-perfect with that, but for some reason it's not in there, just overall EQ. I can adjust bass/treble with each amp, and I have hardware 16-channel EQ for the mains, but nothing real for each channel. Surrounds don't matter too much but it'd be nice to have something more for the center.
I might use the HW EQ for the center, now that I think about it. Adjust the mains with EQ in software (which will also adjust everything else)... then tweak the center with the hardware equalizer and do a rough adjust on the surrounds with bass/treble on their amp. Not much more than that necessary anyway.
With just the Technics amp I couldn't do that, and since I have mismatched speakers (well, mains vs. center & surrounds) it would be a disaster...
Angus_rg
PostLink    Posted: Mon Jun 23, 2008 4:11 pm    Post subject: Reply with quote
Hmmm.... Probably the only thing you can do is update the drivers and or delay powering the speakers on after it boots.
You could try reseating the sound card. I'd also use some canned air to make sure the slot is clean. It's a real long shot, but its worth a try if you haven't already.....
