Site running Sloooooow!
Mad Mr H
PostLink    Posted: Wed Mar 15, 2006 5:14 pm    Post subject: Site running Sloooooow! Reply with quote
UK time 17.12 15/3/06
Pages taking about 6 to 8 seconds to load up
A short reply takes 16 seconds for page to refresh
NOT my PC or load on my broadbean link
Other sites fine....
Worth a check maybe ???
(Usually happens just prior to an issue on other forums.......Hope not)
God_TM
PostLink    Posted: Wed Mar 15, 2006 6:16 pm    Post subject: Reply with quote
Working fine for me... has been all day so far.
Try running a tracert on www.curtpalme.com and see where the delay is at (if it is a traffic delay... could be many other issues).
(sorry if I assume you don't know how to do this, but:) Start -> run... and type in 'cmd'. A console session will open up and you can then type in 'tracert www.curtpalme.com' and it'll list all of the hops it takes you to get to curt's site.
Mine for instance gives me:
C:\>tracert www.curtpalme.com
Tracing route to www.curtpalme.com [82.165.198.238]
over a maximum of 30 hops:
1 2 ms <1 ms <1 ms 192.168.1.1
2 23 ms 22 ms 22 ms L100.DSL-02.PTLDOR.verizon-gni.net [71.111.48.1]
3 22 ms 23 ms 23 ms P1-1.LCR-01.WASHDC.verizon-gni.net [130.81.34.80
4 77 ms 47 ms 48 ms so-6-0-0-0.PEER-RTR1.SJC80.verizon-gni.net [130.
81.17.133]
5 48 ms 48 ms 48 ms so-6-1-0-0.gar2.SanJose1.Level3.net [4.79.54.1]
6 48 ms 48 ms 48 ms ae-1-53.bbr1.SanJose1.Level3.net [4.68.123.65]
7 123 ms 124 ms 124 ms as-3-0.bbr2.NewYork1.Level3.net [64.159.1.134]
8 124 ms 123 ms 124 ms ae-23-52.car3.NewYork1.Level3.net [4.68.97.50]
9 124 ms 124 ms 124 ms level3-up.nyc.schlund.net [4.78.164.2]
10 124 ms 124 ms 124 ms a0nycc2.gw-core-a.nyc.schlund.net [217.160.229.1
04]
11 124 ms 125 ms 124 ms perfora.net [82.165.198.238]
Trace complete.
Does yours give anything much higher than 124 ms? Could be a network issue... otherwise, try a different browser and see if that makes any difference (try Opera, or Firefox (Opera is better IMHO)).
Mad Mr H
PostLink    Posted: Wed Mar 15, 2006 7:40 pm    Post subject: Reply with quote
Hi nothing over 75ms BUT
nuber 2 shows * * * * time out
Same results after 3 checks
Mad Mr H
PostLink    Posted: Wed Mar 15, 2006 7:43 pm    Post subject: Reply with quote
Curts site runs fine, so does google, ebay and about 4 other forum sites
Just the forum here......
PostLink    Posted: Wed Mar 15, 2006 8:28 pm    Post subject: Reply with quote
I'm noticing some slowdowns too... I think it's 100% database related (something I can't do anything about unfortunately).
I've installed some changes to do template (page) caching to reduce some server overhead and that did nothing, so it's not a server CPU load problem.
Also not a networking issue.
That only leaves the database.
When I set up this forum, I was database number 300-something. Lotsa people using that machine as a database server!
linecircle
PostLink    Posted: Wed Mar 15, 2006 8:29 pm    Post subject: Reply with quote
Forum also running slow here. Website is fine. Tracert ~40ms.
There's about a 3 sec delay from sending the forum a http request until data starts coming back at full speed. (delay is 10 sec when making a post)
PostLink    Posted: Wed Mar 15, 2006 9:25 pm    Post subject: Reply with quote
Ok, I give up...
I created a brand new test forum from scratch and the slowdowns still occur even with all default settings.
I did the following
- Creating a brand new database from scratch.
- Did a clean install of phpBB v2.0.19 (changed NOTHING in the admin console).
- Logged in as administrator.
- Posting and pages switches are still slow. Same as on this forum here.
So I can conclusively say, there ain't nothing I can do about it!
My guess is that the server that the hosting company is running our database on overloaded. The hosting company is 1and1.com. The database host name is db???.perfora.net (??? entered to protect the innocent).
I'll check it a few times later in the day (tonight) to see if the performance is better.
We have very few users here and the base app code is clean. Shouldn't be slow like this.
Mad Mr H
PostLink    Posted: Wed Mar 15, 2006 10:08 pm    Post subject: Reply with quote
Ok, almost sorry I asked,
As its not "your" server than thats fine, it was just a heads up as nearly always I have seen this it leads to down time on that forum.......
To be honest most have been array fails and rebuild arrays......
If its not your own server then nothing to worry about....OR as you say nothing you can do about it......
Thanks for trying though......
It is important to keep forums 100% up and running.........
Mad Mr H
PostLink    Posted: Wed Mar 15, 2006 10:09 pm    Post subject: Reply with quote
UK time 22:09 and much faster at the mo 5 seconds for page to dissapear after hitting "submit" then the usual 5 sec wait on the "message entered" page.
PostLink    Posted: Wed Mar 15, 2006 10:16 pm    Post subject: Reply with quote
My fault or not... I still don't like to see it this slow! Smile I hate it when you can't control things...
linecircle
PostLink    Posted: Wed Mar 15, 2006 10:43 pm    Post subject: Reply with quote
An update on my side, things are now instant* again. =D
*more or less
PostLink    Posted: Thu Mar 16, 2006 4:10 am    Post subject: Reply with quote
11PM here (GMT-5) and it's instantaneous as well on this forum and my test forums so it's pretty much conclusive that the problems simply that the shared server we're on wsa just too busy (either server CPU or database).
*sigh*
Unfortunate that the only way out of this is a dedicated server. ($$$)
We'll keep an eye on it over time and see how it goes.
