Hi
I have a G70 running a HD DVD Player @1080P signal via the HD Fury (powered) into the RGBHV input of my G70 over a 7 meter HDMI cable.
I am looking for something that i can use my existing cable and Fury set up and get the Gamma adjustment and hopefully another HD input so I can connect another HD device.
What magic box is out there that will do this?
I think I can use the RTC2200 but i will have to have it sitting at the CRT, Which I can do because it is hidden in a coffee table.
If i can use the RTC2200 what happens if I connect the RGB via the Fury straight from the HD DVD player @1080P and the Component input with 1080i and 560P via my HT Amp at the same time?
