delphiplasma
Link Posted: Wed May 07, 2008 11:48 am Post subject: |
Thanks for the replies!
Apologies Kal, I put your name down as Karl.
I will try out the LCD settings, however, the results using the plasma settings seemed fine, i.e., the results seemed to match what I was seeing. I will be a little concerned if I get an equally good result using the LCD settings.
Maybe someone can give a definitive on which setting is the most accurate?
I've downloaded the HCFR pattern disc, which has all the patterns that are required for the software.
Keep up the good work, with the documentation.
kaitsu66
Link Posted: Wed May 21, 2008 7:37 am Post subject: |
Here is my RGB levels after calibration (eye one) , Blue 0-30 IRE is now ok and i have to set my brightness controll 40 and increase G2 to get that low end level right !
Barco D808s,colored clygol,HD-145.
Thank´s for good instructions Kal
