Power for TC1500?
olly183
PostLink    Posted: Tue Apr 08, 2008 10:29 pm    Post subject: Power for TC1500? Reply with quote
Can anyone tell me the power requirements for the TC1500? is there any documentation to be had?
Regards
Olly
beun
PostLink    Posted: Wed Apr 09, 2008 3:38 am    Post subject: Reply with quote
You need 9V AC on a 3.5mm mono audio plug.
olly183
PostLink    Posted: Wed Apr 09, 2008 8:57 am    Post subject: Reply with quote
I guess that comes as a mains adapter when you purchase the product?
If its 9vac? whats the frequency? is it definitely not dc?
is there an acceptable voltage range?
& what is the power requirement?
If i assume correct and there is a mains supply with this product? what is the ac input to this 100-250vac?
Its just in my application dc is in plentiful supply but not ac, so it looks like i need to put together an inverter of some kind!
note:
I'm going to be using with the HDFury
Regards
Olly
beun
PostLink    Posted: Wed Apr 09, 2008 3:06 pm    Post subject: Reply with quote
Olly,
It comes with power supply. What works is 9-12V AC (NOT DC) 300mA-500mA on a 3.5mm mono audio plug. When you order you will receive a 110V supply in 110V countries and a 220V supply with European prongs in 220V countries.
