jkruger
Link Posted: Thu Jan 03, 2008 3:22 pm Post subject: PCI HDTV Tuner Card? |
I'm putting together a budget HTPC and need to buy as tuner card soon, Which is the best one for OTA and Digital cable? The pc is a 1 gig athlon 64 with a pci-e nvidea 8600gt 512mb, soon to get the LG HD/BLURAY drive. My display is a sony 1272 projector fed with an HDFury. I'm trying to keep the tuner card under $100. I have one empty AGP slot and two empty PCI slots.
Link Posted: Thu Jan 03, 2008 4:48 pm Post subject: |
You don't mention OS, but if you're just using XP and you're in a metro area with good OTA HD reception, you can get used MyHD tuner cards pretty cheap on fleabay from time to time. The older '120' model would easily go for under $100. They have a hardware decoder, so processor utilization is almost nothing. If you're using MCE, it won't work, though.
Google MyHD MDP-120 or 130.
Digital Connection has the older 120 model new in box for $99.
http://www.digitalconnection.com/products/video/mdp120.asp
https://www.digitalconnection.com/store/Product_List.asp?CID=3&CAT=HDTV%20TUNER%20CARD
Saves all recorded files as standard .ts HD transport streams.
If you use AnyDVD, it will work as a scaling DVD player, too.
One other nice thing is it uses it's own video output, so no matter how F'ed up your video timings are on your desktop, it outputs standard DTV resolutions.
Link Posted: Thu Jan 03, 2008 5:03 pm Post subject: |
I had a DVICO Fusion Pci card...
It worked well and i would use it again if i went ota HD again
_________________ Follow my blog
jkruger
Link Posted: Thu Jan 03, 2008 5:21 pm Post subject: |
I have xp pro right now and mce 2005 on the way. Will a tuner card work with cable tv?
Link Posted: Thu Jan 03, 2008 7:00 pm Post subject: |
Yes, Dvico makes one that works w/ QAM cable format..
Checkout their website. dvico.com
Link Posted: Thu Jan 03, 2008 11:31 pm Post subject: |
A friend bought bought a Avermedia USB ATSC tuner for $65 and that was before the $50 MIR.
85.46 KB |
12669 Time(s) |
jkruger
Link Posted: Fri Jan 11, 2008 4:02 am Post subject: |
So... I bought this Wintv-HD HDTV PCI TV Tuner Card ebay# 190187820003
I dont care if I paid too much or whatever... just need to know if it is going to work well with MCE 2005, nVidea 8600gt 512mb, 1 gig athlon board and two 160 gig drives.
jkruger
Link Posted: Tue Jan 22, 2008 4:32 pm Post subject: |
Okay, after installing this Hauppauge card I found out that it is not compatible at all with my system. I should have done more research. I'll ask again, Which hdtv tuner card will work well with an amd athlon 64 with 1 gig ram, with a pci-e nvidea 8600gt 512mb? I want to be able to record and playback OTA and Cable, DVR style.
Link Posted: Tue Jan 22, 2008 6:26 pm Post subject: |
I was going to go with a MyHD 130 card but then I found it won't play nice with a dual core processor. SO now I'm looking too. Have you checked out the dvico cards as sugested? I have to get around to that myself.
Link Posted: Tue Jan 22, 2008 6:32 pm Post subject: |
It doesn't like dual core processors? Are not the only single cores left Celeron? I wonder why its having difficulty.
Link Posted: Tue Jan 22, 2008 6:33 pm Post subject: |
Can't remember the exact reasoning. Check out the AVS thread on it. There are tons of pages about it.
Link Posted: Wed Jan 23, 2008 12:04 am Post subject: |
WanMan wrote: | It doesn't like dual core processors? Are not the only single cores left Celeron? I wonder why its having difficulty. |
I was on the AVS/HiPix open source team back in 2002, I know the HiPix had issues with hyperthread and dual processors and I believe it used the same Teralogic TL880 Chipset as the MyHD card. The card will function perfect an almost junk PC of around 700 MHz or better with 256 mb ram. It was workhorse for me & worked very well and still have several movies on my server I record from HBO & Showtime when you could use a Dish 5000/Modulator combo.
There happens to be one on EBay right now. I have a couple I still use, the software is stable but not at all pretty.
http://cgi.ebay.com/Telemann-Sys-HiPix-DTV-200-HD-HDTV-TV-Tuner-Video-Card_W0QQitemZ150206642112QQihZ005QQcategoryZ3762QQcmdZViewItem
wireburn
Link Posted: Wed Jan 23, 2008 3:21 pm Post subject: |
The only issue with the MyHD and multi-core processors is with DVD playback, as far as I know. I've been using a 130 on my Duo for about a year now.
-Mike
Link Posted: Wed Jan 23, 2008 3:24 pm Post subject: |
wireburn wrote: | The only issue with the MyHD and multi-core processors is with DVD playback, as far as I know. I've been using a 130 on my Duo for about a year now.
-Mike |
Interesting... It may have only been the HiPix that had issue then.
jkruger
Link Posted: Fri Jan 25, 2008 3:09 pm Post subject: |
I see a lot of USB tuner gizmos out there... Are they any better or worse than a card?
ddc3733
Link Posted: Tue Feb 12, 2008 3:15 pm Post subject: Telemann HiPix DTV-200 cards |
I am looking to buy Telemann HiPix DTV-200 cards, though long discontinued.
I wonder if you know of any I could buy - am will to pay top dollar for working main and/or daughter cards.
Thanks in advance for your assistance,
VERONICA FRANK | TECHNICAL SERVICES
Digital Display & Communications Inc. | DDC
TEL: 519-725 -3733 ext 233 | CELL: 519-590-7876
FAX: 519-725-5491 | 1-888 332 2677
www.thefullpicture.com
Link Posted: Tue Feb 12, 2008 4:09 pm Post subject: Re: Telemann HiPix DTV-200 cards |
ddc3733 wrote: | I am looking to buy Telemann HiPix DTV-200 cards, though long discontinued.
www.thefullpicture.com |
I have a couple I might let go of....PM me.
Hope this doesn't break any rules.
Link Posted: Wed Feb 13, 2008 12:29 am Post subject: |
Nope not breaking any rules. So long as it's not a full projector it's ok.
