SNVP
Link Posted: Thu Nov 29, 2007 2:11 am Post subject: Does it have Negative Sync? [EXT-HD] |
What is the rail voltage for the box? I need to know because I need to have negative sync - that is +/- 5V or greater. Does anyone know what the power supply to this box is?
Simon
SNVP
Link Posted: Thu Nov 29, 2007 2:21 am Post subject: Negative Sync |
The EXT-HD - sorry for the confusion
SNVP
Link Posted: Thu Nov 29, 2007 2:22 am Post subject: Need for swing |
We have a processor that needs to have +/-5V swing in order to accomodate the enhanced modulation.
WTS
Link Posted: Thu Nov 29, 2007 2:14 pm Post subject: |
Typically normal sync levels are -.3 v and for tri level it is +/- .3v. Now some units output TTL level sync which is 5v, but I've never heard of a sync signal with a swing of +/-5vdc and I can't imagine where or why it would be required in any circuit. If you want to get those kind of levels get a TTL to RS232 convertor and pad the outputs to +/-5vdc.
_________________ Thanks
Walter
