EDID Update
JustGreg
PostLink    Posted: Fri Sep 21, 2007 8:27 pm    Post subject: Reply with quote
I found the ddcw.exe EDID writer at the same time Clarence. It looks like the zip already has info for an NEC monitor included, which is useless for all but illustration purposes.
I know I'm not going to mess with the EDID in my moome either. Laughing
Greg
EDID_Writer.zip
 Filename:  EDID_Writer.zip
 Filesize:  132.51 KB
 Downloaded:  5388 Time(s)
Greg
Clarence
PostLink    Posted: Fri Sep 21, 2007 8:30 pm    Post subject: Reply with quote
disking wrote:
I use a program called pony prog to write to the EDID chip.
Graham
http://www.lancos.com/prog.html
http://translate.google.com/translate?hl=en&sl=ja&u=http://tomtia.plala.jp/PC/DVIchanger/index.htm&sa=X&oi=translate&resnum=1&ct=result&prev=/search%3Fq%3D%252B%2522pony%2Bprog%2522%2B%252BEDID%26hl%3Den
http://64.233.179.104/translate_c?hl=en&u=http://tomtia.plala.jp/PC/SPD/index.htm&prev=/search%3Fq%3D%252B%2522pony%2Bprog%2522%2B%252BEDID%26hl%3Den
PostLink    Posted: Fri Sep 21, 2007 10:04 pm    Post subject: Reply with quote
overclkr wrote:
I think there needs to be a solution to be able to program yourself from your computer. This way, moome could just email out an updated file to everyone to fix compatibility issues.
Or better yet, just post it on the forum here in a sticky "EDID updates" and no need to email. I'd manage it.
That is a PHENOMENAL idea Kal. I've been having problems with my ISS card for a while now and would LOVE to be able to flash an update to it to fix my problems.
Cliff
PostLink    Posted: Sat Sep 22, 2007 2:08 am    Post subject: Reply with quote
Providing files online won't be the problem of course... that's the easy part! Smile
My newest website:
JohnHWman
TV/Projector: Sony VPH-G90U (one unit for me, four others units repaired and sold)
PostLink    Posted: Sat Sep 22, 2007 9:11 am    Post subject: Reply with quote
Thanks for the reply Graham,
So you are not using DVI, nor HDMI outputs to rewrite the EDID content, you simply use Ponyprog through a serial port of you PC, right ?
What hardware interface do you use between PC serial port and DVI/HDMI device port ? SI-Prog ?
This solution is OK but requires the end-user to have a hardware interface to be able to update his EDID content. The best and cheaper solution for the end-user would be to use a software only based solution though the DVI or HDMI port of the PC graphic card Wink
John
Home theater enthusiast for over 20 years !
My dedicated HT room !
JohnHWman
PostLink    Posted: Sat Sep 22, 2007 9:28 am    Post subject: Reply with quote
Hi Greg,
I know this tool for some time now. Unfortunatly:
- it is usable from pure DOS mode only,
- It allows to read (and write) the first EDID 128 bytes block ONLY (and not the EIA-CEA861 extended EDID block which is the one that often need to be updated nowadays Rolling Eyes )
John
BrianC
PostLink    Posted: Thu Nov 15, 2007 3:36 am    Post subject: Reply with quote
So has anyone had any luck updating from a PC? I have a first gen DVI card for Sony PJ's and would like to update to the latest/greatest EDID info.
Or am I better off just sending Moome the cost of shipping and getting a new chip? What's the current rate?
Thanks,
-Brian
yonexsp
PostLink    Posted: Wed Dec 12, 2007 6:10 pm    Post subject: Reply with quote
Graham
Graham,
Is it possible then using a PC and this program to reprogram the innternal XG DVI Card? If so, do you have a EDID file you recommend to update it with?
moome
PostLink    Posted: Sat Dec 15, 2007 3:48 pm    Post subject: Reply with quote
yonexsp wrote:
Graham
Graham,
yes! it is raw data
moome
PostLink    Posted: Sat Dec 15, 2007 3:50 pm    Post subject: Reply with quote
[quote="moome"]
yonexsp wrote:
Graham
Graham,
yes! it is raw data, for dvi card only!
edid_dvi.zip
 Filename:  edid_dvi.zip
 Filesize:  340 Bytes
 Downloaded:  1174 Time(s)
aspec2
TV/Projector: Maquee 8500
PostLink    Posted: Sat Dec 15, 2007 8:42 pm    Post subject: Reply with quote
Pony Prog and an I squared C (I2C) cable was what was used to update Mits RP TV for red push. Some soldering experience would be necessary. There was another program used for this but I forget what it is called. Old is a bitch.
Walt
yonexsp
PostLink    Posted: Sat Dec 15, 2007 8:50 pm    Post subject: Reply with quote
[quote="moome"]
moome wrote:
yonexsp wrote:
Graham
Graham,
Thx Graham,
Can the reprogramming be done through the DVI port?
K./
moome
PostLink    Posted: Mon Dec 17, 2007 5:41 am    Post subject: Reply with quote
[quote="yonexsp"]
moome wrote:
moome wrote:
yonexsp wrote:
Graham
Graham,
Thx Graham,
K./
yes! the edid on dvi card with no write protect!
kschmit2
PostLink    Posted: Mon Dec 17, 2007 8:35 am    Post subject: Reply with quote
moome,
can the EDID on ISS-HD cards alse be updated from the PC?
Kai
disking
PostLink    Posted: Tue Dec 18, 2007 5:36 am    Post subject: Reply with quote
The EDID chip sits right on the DVI/HDMI connector.
So I made a programmer that plugs into the printer port of my PC.
I then cut a 6' DVI/HDMI cable in two. Wired both cables into the interface box.
This now lets me program both DVI and HDMI Moome cards.
I then read the EDID chips in a Sony 1080p LCD TV, and a Toshiba 1080p LCD TV.
I compered the two chips, morfed them and wrote Moomes header to the new file.
This is the file I use to program all flavers of Moome cards.
If any of you need this to be done on any of your cards. I will do this for $7.50 plus return postage.
Graham
moome
PostLink    Posted: Wed Dec 19, 2007 6:46 am    Post subject: Reply with quote
kschmit2 wrote:
moome,
Kai
yes!
kschmit2
PostLink    Posted: Wed Dec 19, 2007 8:43 am    Post subject: Reply with quote
thank you, that is good to know Smile
sim.m
PostLink    Posted: Mon May 05, 2008 2:14 pm    Post subject: Reply with quote
Hello,
could it be done with a HDfury, so that it accepts 1080p24?
Tx
johndal
PostLink    Posted: Wed May 21, 2008 4:07 pm    Post subject: Reply with quote
I bought the Moome IIS card some time ago to future proof my system while the card was available. I have been feeding some upscaled standard DVD stuff from an Oppo player via the component port and the HDMI port without problems. I have recently bought a multi standard drive for my HTPC and have tried to connect the DVI port on my ATI 2600 XT card (catalyst 8.4 and power strip profile 1440 by 1080 50 Hz0 via an adapter cable to the HDMI input. No joy.
Unde the circumstances I did not worry about the EDID problems some were having at the time I got the card.
Am I right in assuming that the EDID cannot accept that configuration or do I need to reporgam the EDID (better get it done)?
John.
PostLink    Posted: Wed May 21, 2008 4:35 pm    Post subject: Reply with quote
If it were me I would just run analog (RGBHV). I do with my XG and IMO it works just as well.
Page 2 of 3
