that1crzywhtguy
Link Posted: Sun May 28, 2023 7:52 pm Post subject: 1080p@72hz with Iscan Duo? |
I'm reading this page: http://www.curtpalme.com/ChromaPure_iScanDuo.shtm
On that page it states:
"Progressive Cadence Detection™
Enables 24/48/72Hz and 25/50/75Hz output from film-based content at 480p, 576p, 720p and 1080p resolutions"
Does this mean I can get the iscan duo to output 1080p@72hz?
Hulio
Link Posted: Mon May 29, 2023 11:01 pm Post subject: |
Not really. According to the user manual, 1080P@60Hz is max. output resolution.
that1crzywhtguy
Link Posted: Tue May 30, 2023 12:22 am Post subject: |
I wonder what then is meant by that.
that1crzywhtguy
Link Posted: Tue May 30, 2023 3:24 pm Post subject: |
Got it! Thanks for the clarification, Kal.
Too bad the Duo can't handle this as I have one on hand. Guess I'll try to sell it and hope to find a VP50Pro. I've been trying to figure out a cheap solution to get 72hz into my new G90, but I have found that to be an impossible nut to crack.
virusc
Joined: 11 Apr 2007 Posts: 322 Location: Massachusetts
Link Posted: Fri Aug 11, 2023 1:56 pm Post subject: |
Why not look for a Lumagen HDQ. That is supposed to do up to 120hz on the RGBHV analog output and some reviewers said they ran projectors at 72hz. Does a VP50pro do 72hz at 1080p? And what HDMI to analog converter are you using?
that1crzywhtguy
Link Posted: Fri Aug 11, 2023 4:02 pm Post subject: |
I'd obviously be happy with a lumagen at a good price and have a saved ebay search for that also. They just pop up infrequently and are incredibly expensive still. The vp50pro does do 1080p@72. I'm currently running hdmi into my DVI card through a simple converter.
virusc
Link Posted: Fri Aug 11, 2023 4:32 pm Post subject: |
But not any Lumagen just the HDQ which came out around 2006 and should be cheap if you can find one. I do not think any other one can do even HDMI 1080p/72 unless you go to the 4k radiance units. All the other Lumagens like the 20xx,21xx,xd,etc.. only do 1080p/60 from HDMI output. Good luck finding one. I am after the same thing for my Barco 1209s and Curt sold me his HDQ but I have not tested it yet.
that1crzywhtguy
Link Posted: Fri Aug 11, 2023 4:49 pm Post subject: |
HDQ doesn't do hdmi though, so a bit less than ideal in that regard, but yeah... Had a saved search on ebay for years and haven't seen a cheap HDQ ever.
