bluemoonhu
Link Posted: Sat Jan 21, 2023 1:06 pm Post subject: Barco 808S fault |
This is a Barco BD808S fault machine. When the machine is started, the LED lights on each board will show green light, and the tubes can emit a high voltage sound of "zi zi", but the three tubes have no image, I suspect that the drive board is faulty
82.05 KB |
2660 Time(s) |
bluemoonhu
Link Posted: Sat Jan 21, 2023 1:16 pm Post subject: Barco 808S fault |
drive board( fault 808s)
71.33 KB |
2658 Time(s) |
bluemoonhu
Link Posted: Sat Jan 21, 2023 1:18 pm Post subject: Barco 808S fault |
drive board (good 808S)
383.7 KB |
2657 Time(s) |
bluemoonhu
Link Posted: Sat Jan 21, 2023 1:21 pm Post subject: |
I don't know how to solve it
Link Posted: Thu Jan 26, 2023 10:22 am Post subject: |
Have you checked the EHT board for a RED LED. Look down the hole in the top of EHT to see LED.
bluemoonhu
Link Posted: Thu Jan 26, 2023 2:51 pm Post subject: |
If the EHT board is broken, the tube will not have high voltage sound .
Link Posted: Thu Jan 26, 2023 8:37 pm Post subject: |
bluemoonhu wrote: | If the EHT board is broken, the tube will not have high voltage sound . |
Very true. However it does sound like an high voltage issue. I would check the EHT quad and splitter. I have heard arching from a quad and internally in a splitter.
Have you done that?
bluemoonhu
Link Posted: Fri Jan 27, 2023 1:13 am Post subject: |
km987654 wrote: | bluemoonhu wrote: | If the EHT board is broken, the tube will not have high voltage sound . |
Have you done that? |
OK, I will check。Thanks!
bluemoonhu
Link Posted: Mon Jan 30, 2023 1:27 pm Post subject: |
I replaced the EHT quad and splitter,I don't know whether they are in good condition.They have been idle for many years . After the machine was started, I found that the red light in the EHT board was on。
bluemoonhu
Link Posted: Mon Jan 30, 2023 1:28 pm Post subject: Barco 808S fault |
The EHT board
162.82 KB |
2544 Time(s) |
Link Posted: Tue Jan 31, 2023 8:12 am Post subject: |
Okay so now we get to the issue. Which is an EHT issue.
I have attached a Scan Fail Circuit so you can see the components that might cause the red LED.
Download |
Filename: |
ScanFailCircuit.pdf |
57.28 KB |
Downloaded: |
90 Time(s) |
bluemoonhu
Link Posted: Tue Jan 31, 2023 2:04 pm Post subject: Barco 808S fault |
Can you tell me which component in the EHT board is prone to failure? Thanks!
301.44 KB |
2516 Time(s) |
Link Posted: Wed Feb 01, 2023 3:11 pm Post subject: |
None of them. The EHT boards are usually very reliable, unless the quadrupler shorts. If one of the EHT red LEDs is on, then you have a problem with the quadrupler or HV splitter... or a shorted tube.
bluemoonhu
Link Posted: Thu Feb 02, 2023 12:37 am Post subject: |
Curt Palme wrote: | None of them. The EHT boards are usually very reliable, unless the quadrupler shorts. If one of the EHT red LEDs is on, then you have a problem with the quadrupler or HV splitter... or a shorted tube. |
bluemoonhu
bluemoonhu
Link Posted: Thu Feb 02, 2023 4:09 am Post subject: Barco 808S fault |
After replacing the HV quadrupler,start the machine, the tubes can make 'ZI Zi" high-voltage sound, and no red LED lights up in the high-voltage board, but there is no image,Is it the problem with the drive board?
198.68 KB |
2482 Time(s) |
