rotoscoped
Link Posted: Sun May 22, 2022 12:42 am Post subject: Marquee 9500 resetting, "complete initialization" |
Hi all,
I turned on my 9500LC after a few months of not using it and got this message on startup: "performed complete initialization" -- and all my source and channel memory settings had been erased. I set up the source again from scratch, but when I turned on the projector the next day, it gave me the "performed complete initialization" message again, and everything had been reset.
This has happened each time I've since turned on the projector.
I found a 2015 thread (last two posts) that cites the same behavior from an 8500LC. But the 2015 thread ends without any solution to the problem.
I read a Marquee Technical Bulletin that cites this behavior as a software "bug" in v1.18 that's corrected in v1.19. I have v3.4, I believe.
I'll also note that, like the 2015 poster, I am having difficulty initially starting the projector. When I plug it in, and then press power from the remote, nothing happens. I have to unplug, replug, and press power again for it to start. Could this be connected?
Link Posted: Sun May 22, 2022 2:19 am Post subject: |
Your battery is toast on the CLM board. It's a 3 volt one, now discontinued, but a similar cell can be mounted onto the PC board in its place.
rotoscoped
Link Posted: Sun May 22, 2022 3:40 am Post subject: |
Thanks for clearing that up so quickly, Curt. I pulled the board partially out and the battery matches the one pictured here -- square, orange, Renata 175-0. In a battery discussion thread, the concept of using a CR-2032 coin battery in a holder comes up. I haven't got any experience replacing PCB batteries, so I'd welcome any specific recommendations or instructions from anyone.
Link Posted: Sun May 22, 2022 2:09 pm Post subject: |
Unsolder, solder the new one in. Get the polarity correct, or you may nuke a chip. Tim Martin may be able to assist if you can't do it.
Link Posted: Wed May 25, 2022 4:43 pm Post subject: |
Yup
CR2032s can be had with solder tabs. Mount to a chunk of photo board and a few inches of small wire onto the board. I saw some 175s on website for $20+. Kind of greedy.......
rotoscoped
Link Posted: Fri Jul 22, 2022 1:53 am Post subject: |
Thank you both for your help, Curt and Tim.
I managed to get this fix done a couple weeks ago – very pleased to be able to save settings again!
Here's a few pictures of the CLM and the new battery. I tried to use supplies I had on hand – conductive tape to secure wires to the battery, and a lot of heat shrink and electrical tape to wrap everything up.
tschaeikaei
Link Posted: Sat Aug 13, 2022 1:41 pm Post subject: |
Sorry, haven't been active here in a while. Saw your pn, and you know what? Two hours after reading the pn, my test-projector started behaving like you described. Swapped the Renata-cell with a cr2032- holder desoldered from an old PC motherboard and thats it. I would recommend you to get a cell holder as well. Just taping the cell to a wire could possibly develop bad contact over time. And to redo a complete setup isn't fun at all if not needed.
Be aware of first adding the second cell in parallel to the existing one before disconnecting it. Otherwise all data will be lost.
Best regards, Julian
