jbmeyer13
Link Posted: Sun Dec 13, 2020 2:25 pm Post subject: Cardboard box for subwoofer |
I need to transport my M&K MX-5000 subwoofer which weighs 115 lbs. and I don’t have the original box. Does anyone know where I can source the really heavy duty corrugated stuff that the manufacturers use? A trip to loval uhaul or HD isn’t going to cut it..
Link Posted: Sun Dec 13, 2020 2:35 pm Post subject: |
Do you have to actually ship the subwoofer? Reason I ask is that for some reason I never kept the packaging for my sub either (a Paradigm Servo 15 @ 115 lbs) and the couple of times I've had to transport it due to moves I simply do it myself, carefully, in the car. No box. The M&K MX-5000 subwoofer it's about the same size (it's also 115 lbs).
If you truly need to ship it, you may want to consider a freight company and build a plywood box for it.
jbmeyer13
Link Posted: Sun Dec 13, 2020 2:51 pm Post subject: |
I’m in the process of a move but getting it up the stairs would be a lot easier with a box. I can tip it on it’s side; slide it up and then put on a dolly for most of remaining trip to car. Vice versa in storage location. I used a large box when I moved it in but it was really crude and took a lot of time. Need something which is strong enough to move it quickly that doesn’t add a bunch of additional weight ans size.
Link Posted: Sun Dec 13, 2020 3:11 pm Post subject: |
If you're the one handling it, as opposed to shipping gorillas who like to drop things from the top of the truck... then you don't really need a lot of padding or protection. You mostly just need to protect the case from scratches &etc. How about this: wrap it in bubble wrap, then build a custom-sized cardboard box around it. Doesn't have to be uber-strong cardboard; if you want more protection, just use two or three layers. Wrap it up with plastic shipping tape and you have a very well-protected sub.
Loop some ratchet-straps around it to use for handles. I singlehandedly moved 160lb projectors up/down stairs that way.
Link Posted: Sun Dec 13, 2020 8:36 pm Post subject: |
Double wall box from Home Depot or UHaul, moving blankets. That should do it if you're transporting it and not actually shipping it.
jbmeyer13
Link Posted: Mon Dec 14, 2020 12:44 am Post subject: |
Curt Palme wrote: | Double wall box from Home Depot or UHaul, moving blankets. That should do it if you're transporting it and not actually shipping it. |
The bubble wrap and moving blankets are what I typically use but I need a box to get it up the stairs. Nothing at HD or Uhaul is big enough so that’s why I asked. U-line has boxes that will do the job but when you have to buy 10 (with shipping) it gets to be really expensive.
Link Posted: Mon Dec 14, 2020 12:57 am Post subject: |
Worst case, a custom packaging place will be able to custom build a box to suit. I get them made all the time for reel to reel tape recorders, and back in the day, for CRT projectors. Usually about $30 a box. the UPS Store won't be the place to go, call around to find some place that can custom build a cardboard box.
Link Posted: Mon Dec 14, 2020 2:32 am Post subject: |
Hell just build your own. Take two big-enough boxes and cut them to size so they just cover 3 sides centered on one corner. Put them on opposite corners so the sides all meet, and tape 'em together. Two layers of boxes -- on different corners -- if you want more protection. Easy peasy.
