My new babies: Lexicon LX-7's
Goto page 1, 2, 3  Next
PostLink    Posted: Sat Nov 21, 2020 7:44 pm    Post subject: My new babies: Lexicon LX-7's Reply with quote
Against my better judgement I rolled the dice and bought a pair of Lexicon LX-7's on eBay that were "for parts, not working." Much to my surprise it wound up being the best gamble I have ever made on eBay.
I want to get these reanodized in black and have the silk screen redone. If anyone knows a one-stop-shop that I can mail the faceplates to I'd appreciate the reference. Otherwise I will do them locally as there are plenty of options in Chicago.
The photos were blurry in the listing and this was the description:
Lot of 2 Lexicon LX-7 LX 7 Power Amplifier Amp lot. The lot is being sold as is for parts or repair. We powered both on and the blue lights come on for all channels on both amps. But when we actually tested the channels; each amp there was a couple channels that would cut in & out as well as sound distorted. We are unsure what the issues are, there could be other unknown issues as we stopped testing anything as we noticed channels were out on each amp. This lot would be good for someone that wants to possibly swap channels out of one to make one good working unit or someone that wants to repair both and have 2 working LX-7 amps. For the units only as shown, no cables or accessories included. Units have scratches, scuff marks, stains, chips, dings, labels and label residue.
Please do not purchase the lot if you don't agree to buying it in as is condition for parts or repair.
Sold as shown.
Free U.S. shipping
Due to the size and weight of the amps, there will be no international shipping of this lot.
Amps will be packed and shipped in 2 separate boxes.
While the description seemed fishy, I talked to the seller and believed him afterwards. He also had feedback over 1500 with 100% positive. Even so, from the photos he had posted I thought the amps were probably in pretty poor cosmetic condition. Before buying, I also verified that the output transistors are still available from authorized resellers in case that wound up being the issue. The amps arrived and were packed incredibly well. Separate boxes as promised with enough bubble wrap to last me the next two years.
Curt had done me the favor of talking with an authorized Lexicon repair tech and who had made some great suggestions on what to test first. His tech wound up being right on the money and I had them both fully function in less than 48 hours with parts on hand.
With that done, I turned to cleaning them up and much to my surprise the cosmetics came out beautifully! Only one amp has a small bruise above the #4 channel LED (it looks like I partially wiped the "4" off using Goof Off to remove the black scrapes near it), but all the scrapes wound or being black paint or black anodization from other components rubbing them.
I quickly realized that these amps also have very low hours. They are actively cooled and build up dust quickly when used often. One amp was built in 2003 and had more use, but still low. The other was built in 2006 and must have less than 100 hours on it; looked almost brand new inside.
I run my amps at 240 volts so the next thing I had to do was figure out how to convert them. This took half a day and was done except... in my jubilation I reinserted one of the amp modules too soon after I powered the amp down and I blew out a channel Sad I had stupidly left the amp in standby when I plugged in the module and probably didn't let the 100,000 uF of capacitance drain off completely. I heard crackles and sparking and was like, "oh shot."
Lexicon flat out refused to give me schematics even with my contacts at Harmon. So I had to repair the module the hard way with brute force tracing of contacts and diagnostics. Luckily I found a blown opp amp quickly and replaced it and the other four opp amps in the same circuit just in case to bring the channel back to life.
I replaced the loudish ball bearing fans with Noctua "NF-A9 PWM chromax.black.swap" fans of very similar specification. I am so happy with these amps. It's been a nice feeling to have something go so well Smile
Here are pics:
These things are absolute beasts and are difficult to even pickup and put into the rack due to their size and weight. They have been independently proven to be capable of running 200 watts per channel continuously without distortion. When new, they sold for $6000 each between 2003-2006.
You can also bridge four channels on each amp to make each amp have a pair of bridged outputs at 400 watts per channel. I'm running my L, C, R this way. This still leaves me with two extra unused channels as I am currently running 7.2.2. I think some ButtKickers may be in the near future.
I'm in love Laughing
JETI 1211 Spectroradiometer
Klein K10-A Colorimeter
Last edited by CIR Engineering on Fri Feb 19, 2021 11:38 pm; edited 7 times in total
PostLink    Posted: Sat Nov 21, 2020 7:50 pm    Post subject: Reply with quote
This is what my matching MC-10 looks like. You can see why I would like to redo these LX-7's in black.
I've got to get on that.
PostLink    Posted: Sat Nov 21, 2020 8:02 pm    Post subject: Reply with quote
Finally and ironically, I ordered two brand spanking new JBL Synthesis SDA 7200's that arrived a couple days before the Lexicon LX-7's. I took one of the 7200's out of the box because something was rattling around in it (turned out one of the rack mount ears was not secured, but all OK). The 7200's are D class amps and even though my hearing sucks now, my old audiophile sensibilities have trouble accepting a class D amp in spite of their outstanding reviews.
The 7200's weigh less than half what the LX-7's do and feel like toys compared to them. Granted the 7200's are probably around 90% efficient while the LX-7's are probably around +50% efficient because they are of course class AB.
I have not even listened to the 7200's because I think I am going to resell them as brand new in the box from an authorized dealer. Tough decisions... real first world kind of problems Mr. Green
I also have the Acurus amps that I replaced, I really didn't need amps to begin with. I was running three A250's and two A200x3 in the rack with a spare A200x3 for backup. I've always loved those amps too and am not sure I want to part with them either. I bought the first A250 new back in 1995. They have a transformer buzz though that I can't get rid of because of the awful DC on our terrible power here on my street that the Lexicons do not manifest.
Last edited by CIR Engineering on Mon Nov 30, 2020 5:46 pm; edited 1 time in total
PostLink    Posted: Sat Nov 21, 2020 8:23 pm    Post subject: Reply with quote
Wow! Nice find Craig. Lexicon makes some fabulous equipment.
PostLink    Posted: Sat Nov 21, 2020 11:46 pm    Post subject: Reply with quote
Meh sure, but I see amps on Amazon 1000 watts for $99 Laughing
PostLink    Posted: Sun Nov 22, 2020 12:06 am    Post subject: Reply with quote
I also need to find a parts machine so if anybody has an LX-7 that is nonfunctional or only partially functional let me know. I don't care at all about the cosmetics on it.
PostLink    Posted: Sun Nov 22, 2020 4:07 am    Post subject: Reply with quote
Yeah, these were made by Crown for Lexicon I think before Harmon had acquired both Crown and Lexicon. Lexicon makes some excellent pre/pros now along with receivers, but not really any great separate amps. I feel like these are gems.
...now, where can I get them reanodized in black Laughing
PostLink    Posted: Sun Nov 22, 2020 4:08 am    Post subject: Reply with quote
doh! I should have held out!
PostLink    Posted: Sun Nov 22, 2020 9:22 am    Post subject: Reply with quote
AND they're made of the finest quality chinesium Mr. Green
PostLink    Posted: Sun Nov 22, 2020 4:38 pm    Post subject: Reply with quote
LOL Laughing Laughing Laughing
That really did get a good laugh out of me. Thanks for a nice start to the day.
PostLink    Posted: Thu Feb 18, 2021 9:03 pm    Post subject: Reply with quote
I just got the faceplates back today after having them reanodized in black. They were done at Mike's Anodizing Company here in Chicago (859 N Spaulding Ave, 773-722-5778). Mike says he likes doing little projects like these, and he personally spent a good amount of time with me. He gave me a tour of their facility and it is really something and it sure is bigger than I expected. He also said they would take a week, but I brought them in Monday morning around 10:00 and they were finished Wednesday afternoon.
I considered matching the texture of the LX-7's with the MC-10, but Mike said he'd have to send them out for that. It would have taken a week and cost $115 plus shipping. Mike thought I'd be really happy leaving them as-is and boy he was right. It would have been a waste. He also said their military black would be a near perfect match to the MC-10 and he was correct there too. Lexicon black is like pitch black, which is a bit atypical for AV gear, but Mike said this is what the military expects when they ask for black. He really knows his stuff and I highly recommend the company. They also stripped the old anodization before the reanodization. I removed the original silkscreen myself with Goof Off, a Q-tip, a microfiber, and some elbow grease.
I don't want to post pricing because it's not my intention to box them in, but I will say I found the price very reasonable. I really wanted to attempt this on my own, but I doubt my results would have been nearly this good and I am sure procuring everything to do it would have actually cost more (plus a lot of time).
I had to over expose the photos in my theater because it's hard to see anything in there due to the entire room being black and nonreflective. Also, there is a bit of a trick of the light and they don't look the same color in the photo, but they are. I even switched the two faceplates to be sure. I think it's the black leather chair reflecting off the bottom one a bit.
Anyway, I have to decide if I want to restore the original silkscreen or not. I think they look good the way they are already, but maybe they would be better. Mike and some other folks have recommended having them laser etched instead of silkscreen, and Mike gave me a referral for that. I'm waiting for their quite before I decide.
Oh yeah, another thing is that after I took the photos I added neutral density filters to the LEDs so they wouldn't be so bright in my dark room. I just barely like to be able to see them in the dark so they aren't distracting, but they still provide their information (blue is nominal, red is overheat...).
I'm quite please Very Happy
PostLink    Posted: Thu Feb 18, 2021 11:43 pm    Post subject: Reply with quote
Wow - that looks great Craig! I definitely think you did the right thing having them anodized. It would have bugged me as well. Wink
I used to do the same on my bright pre-pro VFD (same idea as yours) back when it was facing into the room. The silly thing was so bright it would light up the room!
PostLink    Posted: Fri Feb 19, 2021 1:26 am    Post subject: Reply with quote
ND Filters? You mean Scotch brand green magic tape and a black sharpie aren't good enough for you? Snob! LOL Laughing
EDIT: Scrolled up to look at the pictures. Looks great! Can I interest you in a roll of Minnesota Mining and Manufacturing Co's Magic Tape an a black sharpie? Smile
PostLink    Posted: Fri Feb 19, 2021 2:29 am    Post subject: Reply with quote
If that would have been dark enough I would have gone that way actually. But I keep gel filters on hand for stage lighting. I had to use two layers of ND1.2 (that's two layers of four stops!) to get them dark enough, and I had thought one layer would be too dark. It was either that or change the resistors, almost did that!
PostLink    Posted: Fri Feb 19, 2021 3:21 am    Post subject: Reply with quote
Now that I think of it, mine weren't probably ND ... they were coloured filters from an an old Avia test pattern DVD. Similar to gel filters used for stage lights that Craig talks about. either way, it worked!
PostLink    Posted: Fri Feb 19, 2021 5:05 am    Post subject: Reply with quote
Thanks Kal,
I知 actually thinking of adding a blue filter to the bottom unit along with, or instead of, one of the ND filters. The bottom unit is an earlier build and the LEDs are more cyan than the bluer ones on the top unit so they don稚 match (I知 sure that痴 the first thing everyone will look at in my demo room Wink. Or, I am still looking for a newer build parts unit so maybe I値l swap them out when I find one. Or, I may change all 14 LEDs so both units match... I literally already bought the LEDs. I think I知 a bit nuts and or OCD.
PostLink    Posted: Fri Feb 19, 2021 1:02 pm    Post subject: Reply with quote
You're posting here, aren't you? You fit right in with the rest of us. Wink
PostLink    Posted: Fri Feb 19, 2021 2:02 pm    Post subject: Reply with quote
Point well taken!
PostLink    Posted: Fri Feb 19, 2021 2:26 pm    Post subject: Reply with quote
Here is one with the dimmed LED's. The photo is still over exposed so they appear brighter than they really are, but you get the idea.
PostLink    Posted: Fri Feb 19, 2021 4:48 pm    Post subject: Reply with quote
Looks amazing Craig! Bet it sounds just as amazing...
Page 1 of 3
