Newbie, questions to ChromaPure
uranos
PostLink    Posted: Sun Feb 02, 2020 8:45 am    Post subject: Newbie, questions to ChromaPure Reply with quote
Hi. I try to calibrate my led TV using an iDisplay Pro and ChromaPure. I read Kal's tutorial for inspiration (thanks Kal for that).
Kal recomends using an Intensity of 75% for colors and 100% for white. My problem is that those numbers appear in more places, I'm a bit confused.
1. On the initial setup page you have the choice to select the pattern source, size and intensity
2. Under "Calibration - Color Mgmt", by clicking the Options button, you are able the choose the desired saturation
3. And finally when using a calibration disc you have all the pattern intesities again.
So what do I have to change? The most of the time I'm using the internal pattern generator. So if I need a 100% white pattern, do I have to change the pattern intensity on the setup page to 100% and then revert back to 75% when measuring colours? Or should I leave it on 75% and only change the saturation values in the colour Mgmt? Can please someone provide me a step by step procedure to do that?
Thanks.
Pics:
https://www.bilder-upload.eu/bild-77218a-1580633560.jpg.html
https://www.bilder-upload.eu/bild-05fadc-1580633630.jpg.html
PostLink    Posted: Sun Feb 02, 2020 10:26 pm    Post subject: Reply with quote
hi! I've sent an email to ChromaPure Support to assist (support@chromapure.com). It's always best to email them directly as they sometimes need to look up your order information and it's impossible to know who you are through the forum.
Cheers!
TomHuffman
PostLink    Posted: Fri Mar 06, 2020 4:39 pm    Post subject: Reply with quote
Leave the Color Intensity setting at 75%.
Almost all modules require a white reading at the beginning. This should always be 100% white regardless of how Color Intensity is set.
In Color Management you can also choose different levels of saturation to calibrate to. 75% is probably best here.
