johnyfazer
Link Posted: Thu Mar 17, 2016 10:03 am Post subject: sony vph cards IFB hdmi |
Hello. I removed my Sony G70. It was my card IFB HDMI Sony VPH. If anyone needs Ifb hdmi please write priv. Real photo. I'll send a package of Polish Greetings.
47.39 KB |
11198 Time(s) |
Ebri
Link Posted: Thu Mar 17, 2016 2:59 pm Post subject: |
Do you reckon this unit to work in a vph1252q?
Link Posted: Thu Mar 17, 2016 5:51 pm Post subject: |
It will, I have one in my 1252. Just be aware you will need to set your source to 1080i or 720p when using HDMI as this card will tell the source it's 1080p compatible.
johnyfazer
johnyfazer
Link Posted: Thu Mar 17, 2016 6:49 pm Post subject: |
whether there is a possibility that modding my card to work in the 808s Barco ?? Is it possible?
robnec
Link Posted: Fri Mar 25, 2016 6:56 pm Post subject: |
hello. is it still available? thank you.
Link Posted: Sat Mar 26, 2016 10:51 am Post subject: |
johnyfazer wrote: | whether there is a possibility that modding my card to work in the 808s Barco ?? Is it possible? |
Yes, most likely. You need to supply the board with its specific supply voltages, but the output is still RGBHV, you just have to mate the IFB card connector with the projector.
johnyfazer
Link Posted: Sat Mar 26, 2016 2:53 pm Post subject: |
Looks great! My only critique is that I hope you have some cooling in that setup, as the Yamaha receiver, and all equipment above it, including the projector will cook themselves quickly if you don't.
johnyfazer
Link Posted: Sat Mar 26, 2016 3:02 pm Post subject: |
gjaky wrote: | johnyfazer wrote: | whether there is a possibility that modding my card to work in the 808s Barco ?? Is it possible? |
Yes, most likely. You need to supply the board with its specific supply voltages, but the output is still RGBHV, you just have to mate the IFB card connector with the projector. |
I thought so. I am an amateur electronics. Physically connecting contacts Barco vs moome I can do. I have a meter, but I do not know how to measure the voltage in order to enable the association pin Barco vs moome
johnyfazer
Link Posted: Sat Mar 26, 2016 3:18 pm Post subject: |
Curt Palme wrote: | Looks great! My only critique is that I hope you have some cooling in that setup, as the Yamaha receiver, and all equipment above it, including the projector will cook themselves quickly if you don't. |
Thanks for your feedback. I did it yesterday. You're right, I will think about additional cooling.
johnyfazer
Link Posted: Mon Nov 04, 2019 4:20 pm Post subject: |
Hi . I have the opportunity to buy Barco cine 8 onyx. I have a further converted retrographhics 808s with lc sony vph g70 lenses. I am very pleased with this. Will barco cine 8 onyx be even better? Does anyone know what lamps are inserted into cine 8 onyx?
johnyfazer
Link Posted: Mon Nov 04, 2019 4:27 pm Post subject: |
onyx = USD 130, good lamps in ranking 9
Link Posted: Mon Nov 04, 2019 5:55 pm Post subject: |
I don't think the Onyx will be any better, but at $130 USD, give it a try. Not sure of what tubes are in it, sorry! Most likely P16 tubes, but I think those are also in the 808 retro unit as well.
johnyfazer
Link Posted: Mon Nov 04, 2019 6:22 pm Post subject: |
OK thanks. In retro I have pt18 probably panasonic
Link Posted: Tue Nov 05, 2019 6:25 am Post subject: |
Unfortunately the Onyx will have poorer lens (HD-215) than the G70, they don't even have corner focus adjustments. Otherwise the Onyx is mostly the same as the RG808s, if nothing else you'll have some spare parts.
johnyfazer
Link Posted: Thu Nov 14, 2019 4:02 pm Post subject: |
Hi. I found another projector in Poland: "Barco Retro Block Reality 908". The projector has 500 hours of lighting, the lamps are perfect. It looks the same as RetroGraphics 808s, of course without the rear projection housing. Can anyone write something about this projector? Lack of information. I don't know yet which lenses are mounted on. Will this generally be better than my 1980s retrograms? I have another set of lenses and "c" elements from Sony VPH G70 that I could wear up to 908.
Link Posted: Fri Nov 15, 2019 3:34 am Post subject: |
johnyfazer wrote: | Hi. I found another projector in Poland: "Barco Retro Block Reality 908". The projector has 500 hours of lighting, the lamps are perfect. It looks the same as RetroGraphics 808s, of course without the rear projection housing. Can anyone write something about this projector? Lack of information. I don't know yet which lenses are mounted on. Will this generally be better than my 1980s retrograms? I have another set of lenses and "c" elements from Sony VPH G70 that I could wear up to 908. |
Thats not anything like 808s. That unit is a 909 with 8inch tubes instead of the 9inch tubes. In terms of lenses and games someone else might have that info.
johnyfazer
