Analog Way Di-Ventix vs. Di-Ventix II
ElTopo
PostLink    Posted: Sun Aug 12, 2018 2:50 pm    Post subject: Analog Way Di-Ventix vs. Di-Ventix II Reply with quote
Any difference between those in edge blending ?
thanks
Barco Cine 9 the one and only
PostLink    Posted: Sun Aug 12, 2018 5:22 pm    Post subject: Reply with quote
Guys
I probably have more experience with edge blending than anyone else here and Yes I have a Di-Ventix 8022 on Ebay.
It is an auction with Buy It Now at $1795, free shipping in USA. Included with my 8022 are the setup guide I wrote and my unlimited phone support for your assistance.
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https%3A%2F%2Fwww.ebay.com%2Fitm%2FANALOG-WAY-Di-VentiX-DVX8022-Computer-Video-Up-Down-Mixer-Scaler-Switcher%2F253813321405&campid=5336656890&toolid=20008
One DVX8022 with power cord, latest firmware installed, a ten foot RS232 cable, remote control .exe for PC on disc, test patterns and user manual on disc.
The Di-Ventix II (aka DVX8044) was developed to offer more/better special effects for broadcasters. It also switches stereo audio that follows the analog video inputs, but has only one DVI-D digital in, so not likely anyone here would care about audio switching in the 8044. The 8044 was $7500 higher MSRP ($24,000 vs $16,500) and has no advantages for our application. Recommend you switch video sources with a Moome MUX (4 HDMI in with stripping)
The DVX may be controlled by its front panel or by a Windows PC with RS232 (Win98 or XP), which is much easier. Compatible input signals include composite, S, component, RGB 3, 4 or 5 wire, DVI-D or HDMI with appropriate cables and/or HDCP stripper. The signal type for each of the eight inputs is user-selectable. A ninth input which is DVI-D can be assigned to any of the eight input buttons.
In home use, one can Edge-Blend across two nine inch CRT projectors like I use, or one could run single projectors in two different rooms with switching, transcoding and scaling all easily selected. For more information on home theater edge-blending just search "BlendZilla" to learn more about a world-class system on a ten foot screen in your living room. Unit is tested in Matrix Switcher and Soft Edge Blending modes and is believed to be fully functional, with a few lid scuffs.
DVX8022 is a broadcast-grade switcher/transcoder/scaler with effects, originally listing for $16,500
Specifications here: http://www.analogway.com/files/uploads/produit/download/en/dvx8022-diventix-mixers-seamless-switchers-technical-datasheet.pdf
Free UPS Ground Shipping to Lower 48 and Canada
PM me with your questions, or e.mail me at ehometech8022@yahoo.com
PostLink    Posted: Sun Aug 12, 2018 8:34 pm    Post subject: Reply with quote
Tim, just one thing, FYI, UPS will usually charge exoberant brokerage fees when shipped to Canada.
USPS with tracking is usually best to Canada. Usually a $5 or so brokerage fee and takes chaged if they decide to charge anything at all.
PostLink    Posted: Mon Aug 13, 2018 3:24 am    Post subject: Reply with quote
Noted Thanks
PostLink    Posted: Mon Aug 13, 2018 6:21 pm    Post subject: Reply with quote
Guys
My Ebay listing is back up.
ElTopo
PostLink    Posted: Tue Aug 14, 2018 5:06 pm    Post subject: Reply with quote
Tim,
what resolution have you configured ?
1920 x 1080p into the Di-Ventix and 1280 x 1024 out to each ?
cheers
ElTopo
PostLink    Posted: Wed Aug 15, 2018 2:17 pm    Post subject: Reply with quote
That's right.
To go to the next level in edge blending you would need Analog's NexTage processor, starts around $18,500
ElTopo
PostLink    Posted: Wed Aug 15, 2018 2:35 pm    Post subject: Reply with quote
Thanks.
Next level means what ?
Does the Di-Ventix do 72Hz ?
PostLink    Posted: Wed Aug 15, 2018 6:52 pm    Post subject: Reply with quote
Next level means an appreciably better picture than Di-Ventix.
60hz is smooth on Di-Ventix so not sure 72hz is needed.
PostLink    Posted: Mon Aug 20, 2018 9:24 pm    Post subject: Reply with quote
Guys
He bought a DVX (not mine) so this should be exciting!
