Advent Videobeam 1000 Screen
Goto page Previous  1, 2, 3, 4, 5, 6
jmetal88
PostLink    Posted: Wed Aug 01, 2018 12:53 am    Post subject: Reply with quote
jmetal88 wrote:
Here's a picture of the screen itself. I'm still working on adjusting the setup. I'm thinking it might be a better idea to set the angle off, so that the hot spots are off the top of the screen. That gives uneven brightness from top to bottom, but I think that might be less annoying for me to deal with.
Eh, this setup was good for some content, but not good for others. I think it may just be best to deal with the hot spot for now.
EDIT: I decided to try seeing what putting strips of tape in front of my lenses would do to the picture. It actually helps, surprisingly enough. I arranged them to dim the light coming from the outside halves of the red and blue lenses and it does make the color gradient a lot less noticeable (although it isn't totally eliminated). Interesting discovery.
The hot spot in the middle of the screen is still noticeable, though, and probably can't be eliminated unless I take Mocom's suggestion and move the projector further back (which I don't know if I want to do since that would leave me with a significantly smaller phosphor area to use -- but maybe if I decide to upgrade in the future I can look for a projector with a longer throw for a given screen size).
PostLink    Posted: Wed Aug 01, 2018 7:24 am    Post subject: Reply with quote
Moving it back makes no sense. I tested a retro reflective screen here. My projector is on a cart just over my head. Hot spot was there but color cast wasn't as noticable
UncleWill
TV/Projector: Electrohome 8500
PostLink    Posted: Fri Aug 03, 2018 7:34 pm    Post subject: Reply with quote
Can we see some pics of the new screen in use?
jmetal88
PostLink    Posted: Fri Aug 03, 2018 7:59 pm    Post subject: Reply with quote
I've been having a hard time getting my phone to focus on it for some reason.
But here's a (blurry) shot from after I put strips of tape in front of my lenses to even out the color gradient.
 Filesize:  97.25 KB
 Viewed:  3869 Time(s)
PostLink    Posted: Fri Aug 03, 2018 9:13 pm    Post subject: Reply with quote
That looks like you took a picture of a rear projection TV
jmetal88
PostLink    Posted: Sat Aug 04, 2018 4:08 am    Post subject: Reply with quote
The focus is a little better here, but I'm struggling to take a picture in a way that doesn't exaggerate the hot spot (the corners really don't look this dim in person... I mean, they do still look dimmer than the center of the picture, it's just really not as noticeable as it is on camera).
 Filesize:  79.77 KB
 Viewed:  3847 Time(s)
PostLink    Posted: Sat Aug 04, 2018 7:06 pm    Post subject: Reply with quote
If you have a camera put it in manual mode and try adjusting the shutter speeds
jmetal88
PostLink    Posted: Sat Aug 04, 2018 8:07 pm    Post subject: Reply with quote
I've been trying, but so far the latest phone picture still looks the best, haha.
I think it's just a case of the hot spot being too much of a brightness variation for the camera sensors to handle, whereas the human eye kind of adjusts itself so that it winds up looking like a normal picture.
PostLink    Posted: Sat Aug 04, 2018 9:19 pm    Post subject: Reply with quote
I found adjusting f stop and shuter speed for a timed exposure worked well. I was using my old Canonn G6
jmetal88
PostLink    Posted: Sun Aug 05, 2018 1:02 am    Post subject: Reply with quote
Well, I decided I just was not happy with the way the Videobeam looks on the Mocom screen. While I can get the Sony projecting on it acceptably well, there's just no way to adjust the Videobeam for an image with even brightness on it (not to mention the angle adjuster can't move far enough in, so I actually had to take it off the wall to aim the new screen down at the Videobeam). So, I thought, why compromise? I moved the Videobeam down to the other end of the basement and set it up to project on the old screen across the short side of the basement next to the bathroom. Now I have two home theaters in my basement! One semi-modern CRT setup and one totally vintage CRT setup! My only problem is that this will displace part of my 'computer museum' and now I have a lot of reorganizing to do.
PostLink    Posted: Sun Aug 05, 2018 2:25 am    Post subject: Reply with quote
Haa great work around! Just FYI within arms reach tonight I have 2 CRT projectors, 2 CRT TV's and one flat screen TV as well as 3 flat screen monitors and this lap top. You can never have enough screens.
jmetal88
PostLink    Posted: Sun Aug 05, 2018 2:29 am    Post subject: Reply with quote
Heh, I have a flat screen and a 32" CRT in my living room as well. I use the LCD for all my digital stuff and the CRT for all the analog (Laserdisc, CED, VHS, and Betamax currently).
PostLink    Posted: Sun Aug 05, 2018 4:55 pm    Post subject: Reply with quote
One of the CRT Tv's has a VHS built in but it being held up on a Betamax.
I never got into CED. How's the picture?
jmetal88
PostLink    Posted: Sun Aug 05, 2018 4:59 pm    Post subject: Reply with quote
Pretty bad, honestly. If I'd paid market price for it, I'd have been disappointed. But I got the player and a box of ~20 movies at a Salvation Army store for $20, so that was hard to pass up.
PostLink    Posted: Sun Aug 05, 2018 5:30 pm    Post subject: Reply with quote
Yeah I've resisted buying CED quite a few times. The last time I saw it the Salvation Army wanted $60 per disk LOL
jmetal88
PostLink    Posted: Sun Aug 05, 2018 7:20 pm    Post subject: Reply with quote
Yeah, that is pretty high. When I bought mine, it had been marked down twice (I think it was originally $60 for the set, and was marked down to $50, then $20 by the time I found it).
UncleWill
PostLink    Posted: Tue Oct 23, 2018 4:04 am    Post subject: Reply with quote
I have a soft spot for CED. Watched so many movies on that format.
Also the proud owner of two CRT beamer setups.
UncleWill
PostLink    Posted: Tue Jan 29, 2019 4:08 am    Post subject: Reply with quote
You guys might find this of interest - a NOS curved projection screen: https://www.ebay.com/itm/Panasonic-Curved-Projection-Screen-60-inches-diagonal-with-stand-OSS-New-In-Box/273049484500
PostLink    Posted: Tue Jan 29, 2019 5:24 am    Post subject: Reply with quote
Oooo nice. Shipping is twice the price though....ouch!
Page 6 of 6
