bvgoor
Joined: 04 May 2018 Posts: 14 Location: United Kingdom
Link Posted: Fri May 04, 2018 1:22 pm Post subject: Barco Cine 7 |
Hello all,
I'm new to the forum, trying to resurrect a barco cine7, tried to use search to see if that would get me anywhere.
The problem i have at the moment, it comes out of standby, i think i hear the HV coming up followed by a ticking sound out of the front spms board.
The front led show, all green lights expect HTHD and 1 red led is on SF.
Any idea? is this typicall of a quadrupler failure?
Thanks in advance
Bas
Link Posted: Fri May 04, 2018 1:39 pm Post subject: |
Make sure it is the SF light that comes on. It's easy to miscount the red LEDs.
IF it is a SF fault, then it's usually a problem on the deflection board, which is the board that is in the middle of the flip up tray that covers the tubes. You'll need circuit tracing/diagnosis skills to narrow that down.
bvgoor
Link Posted: Fri May 04, 2018 1:58 pm Post subject: |
Whoa what a swift reply, thanks
tried again and it is the SF light for sure
other thing to mention is that all green leds are on until it starts ticking, 5 sec after coing out of standby and then the HTHD green led goes off, the rest of the green ones stay on
bvgoor
Link Posted: Fri May 04, 2018 2:13 pm Post subject: |
Sorry for spamming my on topic
okay powered on with the top cover removed and board flapped up (you hopefully get what i mean) and yes there is a red led on the deflection board illuminated (Horizontal Scan Fail)
That means the board is bad?
bvgoor
Link Posted: Thu May 31, 2018 12:29 pm Post subject: |
Okay managed to get another cine 7 with a different problem, replaced the deflection board and the issue is the same
any ideas?
thx
Bas
Link Posted: Thu May 31, 2018 1:27 pm Post subject: |
Try swapping out the power supply and the whole RGB input board tray.
bvgoor
Link Posted: Fri Jun 01, 2018 7:43 am Post subject: |
Okay tried the power supply switch same result
I’ll go on and do the RGb boards next
Thx
Bas
