davelong
Link Posted: Thu Jan 12, 2017 9:10 am Post subject: how do you calibrate a Samsung SUHD TV that has HDR+ ?? |
for some years I've had an older i1 calibrator that I've used on laptops etc and always intended to upgrade to the version suitable for LED and plasma TV calibration (but haven't yet). Last week I bought a new samsung 49" 7000 series SUHD TV that has in the picture expert settings the 'HDR+' mode. This got me thinking....
1. If a TV is calibrated would this mode need to be switched off during the calibration (and the TV set to 'standard' picture mode)
2. Once calibrated, would switching HDR+ back on negate the calibration (or would HDR+ still keep the correct relationship)? I don't know how HDR+ actually works but can see the benefit on screen when it is enabled.
3. Assuming there is a product in the range that could be used, which would be the cheapest (i wouldn't be doing this as a living but would probably end up doing extended family)
TomHuffman
Joined: 01 Jun 2010 Posts: 76 Location: Springfield, MO
Link Posted: Thu Jan 12, 2017 1:48 pm Post subject: |
1. Upgrade to v3.1
2. Select HDR as the reference Gamma.
3. Select Rec. 2020 as the Reference Gamut.
4. Purchase some HDR test patterns--Ryan Masciola sells a reasonably priced suite of test patterns.
Calibrate gamma and grayscale in the normal way.
Later this moth we will release an update that allows you to calibrate color as well.
_________________ ChromaPure calibration software & meter packages at CurtPalme.com discounted prices!
davelong
Link Posted: Thu Jan 12, 2017 6:23 pm Post subject: |
Thanks Tom. I'll look out for the update and also look into the HDR test patterns.
Its been a while since I did any of this so I'll have to 'read' myself back into it!
