Barco 808 issues
whoopn
PostLink    Posted: Mon May 09, 2016 2:40 pm    Post subject: Barco 808 issues Reply with quote
I have an 808 that has bright smearing (in other words the brights instead of making a dot will make a streak horizontally).
Does anyone have ideas on how to resolve this?
tschaeikaei
PostLink    Posted: Mon May 09, 2016 2:42 pm    Post subject: Reply with quote
Do you have a picture. If I'm guessing the problem right, this could be either astig or internal reflections in the tube.
Regards, Julian
whoopn
PostLink    Posted: Mon May 09, 2016 9:31 pm    Post subject: Reply with quote
https://goo.gl/photos/pNHE7BhJbNAYfC3k7
Don't make the image too big, its just blurry (iphone had no idea what to focus on) but you can see the issue here on the building on the left. See the brightest point? It's white shoots out another ~15% of the screen's width before decaying.
Thanks for taking a look
PostLink    Posted: Mon May 09, 2016 11:53 pm    Post subject: Reply with quote
Do the internal menus and test pattern do it too?
whoopn
PostLink    Posted: Tue May 10, 2016 2:38 am    Post subject: Reply with quote
I don't believe so. Though the issue is only with bright whites and essentially high contrast scenes.
Is there a part of the menu that I could test better?
