Moome External DVI transcoder- Power adapter
picree
PostLink    Posted: Sun Mar 20, 2016 7:05 pm    Post subject: Moome External DVI transcoder- Power adapter Reply with quote
Does anyone remember what the power supply specs are for this moome box? I lost the manual and can't find the PS. My bad I guess but hoped someone here might have the 8 1/2" x 11" manual that came with it or they might know off the top of their head. I have searched everywhere. Thanks. (no it's not silkscreened on the board inside...I checked).
Curt
 Filesize:  174.97 KB
 Viewed:  13444 Time(s)
MAIN THEATER: (JVC RS2000; Yamaha UDP-LX500; Yamaha RX-V2400; Lumagen Radiance Pro, Vertex)
SECOND WII-ATER: (BG808; WII; Oppo 971H; Moome external box; BG-DVI transcoder; tse gamma box; Extron)
BobNelson
PostLink    Posted: Fri Mar 25, 2016 12:36 am    Post subject: Reply with quote
Mine says the output is 9 volts.
Martinized and Parkerized 9500LC
PostLink    Posted: Fri Mar 25, 2016 12:53 am    Post subject: Reply with quote
AC or DC? If it's DC what is the polarity?
picree
PostLink    Posted: Fri Mar 25, 2016 10:41 am    Post subject: Reply with quote
Thanks Bob!
I would have assumed DC but that's a very good question! Please share Bob.
BobNelson
PostLink    Posted: Fri Mar 25, 2016 12:36 pm    Post subject: Reply with quote
I just assumed that all wall warts were DC and the same except for voltage. This one says +9 volts.
PostLink    Posted: Fri Mar 25, 2016 2:21 pm    Post subject: Reply with quote
No, some will not have a built in rectifier so they output AC. If it's DC, polarity is up for grabs too. Some will output + on the outside of the barrel, some on the inside. The bigger outside is what is normally negative (-) but you never know. If you have a multimeter you can test by setting it to DC volts and checking.
picree
PostLink    Posted: Fri Mar 25, 2016 5:45 pm    Post subject: Reply with quote
You didn't necessarily volunteer for this but considering you are my only hope at the moment it would be REALLY great if you had a meter and could check if it's AC or not. Neutral
PostLink    Posted: Fri Mar 25, 2016 6:00 pm    Post subject: Reply with quote
You can also email moome and ask. He would most certainly know. He's at moome.liu@gmail.com or moome@seed.net.tw
picree
PostLink    Posted: Fri Mar 25, 2016 6:01 pm    Post subject: Reply with quote
OK, I'll do that. It's just that, historically, he was always very hard to get hold of.
picree
PostLink    Posted: Fri Mar 25, 2016 6:06 pm    Post subject: Reply with quote
FYI. moome@seed.net.tw bounced back to me and may not be valid any longer.
BobNelson
PostLink    Posted: Fri Mar 25, 2016 11:14 pm    Post subject: Reply with quote
Alright, it measures 9.1 volts DC. When it says +9 volts it must be DC. You wouldn't say +9 Volts AC. Or am I all screwed up? Very Happy
picree
PostLink    Posted: Sat Mar 26, 2016 11:06 am    Post subject: Reply with quote
Well you could tell with the meter since an AC adapter would measure zero volts DC but would measure the stated volts on AC (on AC switching the leads around would give the same result). A DC adapter would measure +VDC with the leads one way and -VDC with the leads the other way. And a DC adapter would measure 2x VAC one way and zero VAC with the leads reversed. (At least that's how my multimeter works.)
Last night I found an adapter in a drawer in the garage. It's the only one I can find that has a plug that fits the transcoder. But it says 9VAC output. Based on what Bob says this would not be the right one though. Is it possible the box works with either AC or DC?
"Paging Dr. Moome..." (Maybe he will reply after the weekend.)
PostLink    Posted: Sat Mar 26, 2016 1:41 pm    Post subject: Reply with quote
Strange. Been using that one for years.
moome
PostLink    Posted: Sat Mar 26, 2016 4:35 pm    Post subject: Reply with quote
hi, Picree, can you open the box and take a picture for me check?
I lost the original design document in my old computer.
thanks
picree
PostLink    Posted: Sat Mar 26, 2016 11:18 pm    Post subject: Reply with quote
As requested. Thanks moome.
 Filesize:  478.72 KB
 Viewed:  13270 Time(s)
moome
PostLink    Posted: Sun Mar 27, 2016 5:08 am    Post subject: Reply with quote
hi, you can use either 9V AC or 9V DC, 9V DC will better for less case temperature.
picree
PostLink    Posted: Sun Mar 27, 2016 12:02 pm    Post subject: Reply with quote
Thank you moome. Thumbs Up
moome
PostLink    Posted: Tue Mar 29, 2016 2:46 pm    Post subject: Reply with quote
OK~~~
