Joined: 05 Jun 2010 Posts: 2750 Location: Budapest, Hungary
Link Posted: Sat Apr 26, 2014 1:44 pm Post subject: Re: Moome HDMI card
gregstv wrote:
Hi Guys,
Does anyone have one of these for sale? I would like to update the DVI card in my XG75.
Thanks,
Greg
What advantage do you expect from the newer card? I also have a Moome DVI card in my XG, but haven't even tried yet, and don't know anything about its performance, but I plan to use it in the near future... _________________ projectors in the past : NEC 6-9PG xtra, Electrohome Marquee 6-7500, NEC XG 1351 LC ( with super modified Electrohome VNB neckboard !!!)
The MOD: VNB-DB
Link Posted: Sun Apr 27, 2014 7:55 am Post subject: DVI Moome card
I don't know if the DVI card will work with the latest Oppo BDP103 player. I think its the first gen of the Moome card.
Some say the first revision of the DVI card are not HDCP compliant. I am going to set it all up on a coffee table and sort everything out before I mount it on the ceiling. Once mounted it will be hard to replace the card as it will be close to the back wall. I will post back how it works.
Greg
Link Posted: Sun Apr 27, 2014 2:43 pm Post subject:
I also did some search. I have the PWC-M2005A+ board, which looks exactly like this one. Now, Moome says here it is better than a HDFury (I guess he meant it for HDF 1 to be exact). Yonexsp says here that this boards is stripping HDCP nicely. _________________ projectors in the past : NEC 6-9PG xtra, Electrohome Marquee 6-7500, NEC XG 1351 LC ( with super modified Electrohome VNB neckboard !!!)
The MOD: VNB-DB
Link Posted: Tue Apr 29, 2014 11:17 pm Post subject: Moome card
Hi Guys,
I fired up the XG and connected the oppo BDP103 to the DVI input of the Moome card. Lots of problems. Intermittent vertical and horizontal sync and no Blue. Move the cord and the problems would come and go. I removed the card and inspected it under a microscope. Every pin on the large back connector had cracked solder joints. I reflowed all the pins and refitted. All working well now. No problem with HDCP.
Greg.
