HIGHEST resolution video card with RGB or component outputs?
TV/Projector: I'm building a projector fort!
PostLink    Posted: Sat Feb 27, 2016 5:42 am    Post subject: HIGHEST resolution video card with RGB or component outputs? Reply with quote
I'm on the quest for the highest resolution capable video card I can possibly find.
The catch: It needs to have ANALOG outputs. RGB (RGBHV or RGBS) or YUV or YCrBr.
Currently I can generate up to 2048x2048.
I need MORE.
It doesn't have to be particularly suited for video at its highest resolutions. Frame rate is not a consideration, really.
It'll be used as a test pattern generator as its primary purpose.
The reason for this: I've acquired the parts needed to build what could quite well be the highest resolution CRT projector
ever made. (Potentially, not absolutely certain.) I need ways to see just how far it can be pushed.
