Edge blend 2 x Barco 919 tryout
PostLink    Posted: Sat Nov 21, 2015 1:09 pm    Post subject: Reply with quote
^ agreeed For testing purposes a white wall is fine but I can attest that the difference from a matte white wall to a good screen, in my case a Stewart Studio Tech 1.3, was immense! No comparison.
Absolutely, my screen made the image quality 200% better with the Barco, mostly due to the convergence being achievable on the perfect flat surface where it was not on the wall, due to the inferior fine adjustment.
The NEC didnt suffer that, but image quality is still much improved, contrast ratio is better, the lines are sharper, and its overall brighter.
The screen would certainly make a blend zone easier to align and maintain, being that if installed correctly, itll be dead flat corner to corner, which is pretty important with a Barco ( and probably anything else thats not an NEC )
redfox001
PostLink    Posted: Sat Nov 21, 2015 2:02 pm    Post subject: Reply with quote
Yes that studiotek 1.3 screen is appealing to me too because it seems to have a 1.3 in direct angle and from the side it reflects less.
http://stewartfilmscreen.com/screen-materials/flexible-front-projection/studiotek-130-g3
I read:
Edge Blending Properties Fair
Why is that?
He that is funny the 1.0 gain has the best edge blending properties. Guess I am going for my painters cloth Wink
redfox001
PostLink    Posted: Tue Nov 24, 2015 1:52 pm    Post subject: Reply with quote
Ok this is what I will probable do.
I will make a screen from linen form the artpainter shop. I use that in my HT now and it is perfect and very strong. I will need something close to 270 cm x 150 cm so I can transport the whole screen to my darkened HT later.
http://www.petervanginkel.nl/cat/341/schilderdoek-op-rol
Costs likely close to 60 euro. But I will need the spantang for 50 euro and I will staple the cloth to a frame.
tschaeikaei
PostLink    Posted: Tue Nov 24, 2015 4:31 pm    Post subject: Reply with quote
If you are serious about screens, you will think about higher gains at some point.
I know they tell you that only gain 1 is good for blending and since my setup is not finished
i can't tell you if it will work with two projectors, but i would really wonder if not.
My material is even cheaper and fits your size requirements.
http://www.stoffamstueck.de/shop/themen2/technische-gewebe-zeltstoff/polyester-leinwand-silber-beschichtet.html
This is what i use in 315x170cm and (with a single projector setup) it looks very good.
Colors and contrast are far better than on a white screen!
Try it, you probably won't be disappointed. And keep in mind, that you can use every 3D system on silver screens.
They're not only good for polarisation. The key is to get the most light back from the screen to your eyes or glasses.
I'd build a curved setup about 5% (5% means 13,5cm depth in the middle). Building a curve isn't much more work than
building a flat surface. Building the torus was a real disaster (in my case) but curved is easy.
If you are interested, i can send you some pics of my screen.
Regards, Julian
redfox001
PostLink    Posted: Tue Nov 24, 2015 9:15 pm    Post subject: Reply with quote
That looks very interesting. Is it possible you send me a very small part of this material at my costs? I send my email to you in pm. I could do some measurements with my i1pro to see how it compares.
On this place I did some measurements on linen.
http://www.htforum.nl/yabbse/index.php?topic=128693.25
It reflected almost like a 1.3 gain screen.
tschaeikaei
PostLink    Posted: Tue Nov 24, 2015 11:10 pm    Post subject: Reply with quote
Oh i like that language! It's kind of readable for German people with some imagination.
Sure i will send you some piece of this stuff.
That is kind of interesting for me, too.
I don't know what gain factor it is, just did some fast testing with polarisation glasses.
And using those, it worked quiet good. You know.. i don't plan to use polarisation, but i could!
Regards, Julian
redfox001
PostLink    Posted: Thu Nov 26, 2015 9:03 pm    Post subject: Reply with quote
So this one has perfect LUG tubes now. No 90 degrees and no pt22.
Hulio
PostLink    Posted: Thu Nov 26, 2015 9:17 pm    Post subject: Reply with quote
Nice. Where are those green and red C-elements ?
redfox001
PostLink    Posted: Thu Nov 26, 2015 9:39 pm    Post subject: Reply with quote
They are still on my Cinemax. Have to get another two.
ElTopo
PostLink    Posted: Wed Dec 09, 2015 12:33 pm    Post subject: Reply with quote
How is the project going ?
Blending Shocked Mr. Green
Barco Cine 9 the one and only
redfox001
PostLink    Posted: Wed Dec 09, 2015 2:24 pm    Post subject: Reply with quote
Tested a lot of components to find the quietest solution and it turns out they all are quiet. The Cinemax is not quieter than the others I found out.
Next thing will not be the screen or the blending but the video path.
I will work on the schematics trying to find solutions for better parts but first we have to know where the performance problems are exactly. We are working on that problem. I am sending boards abroad Smile
Still have to make me a screen.
ElTopo
PostLink    Posted: Wed Dec 09, 2015 5:01 pm    Post subject: Reply with quote
I hope it will be a 2.40 screen. What screen size ?
redfox001
PostLink    Posted: Wed Dec 09, 2015 5:18 pm    Post subject: Reply with quote
Yes something like 2.40.
I want to get a sample of screeninnovations blackdiamond material. See if it is something for me.
ElTopo
PostLink    Posted: Thu Dec 10, 2015 1:01 pm    Post subject: Reply with quote
This would be my setup if i will ever realize it Mr. Green
Screen = 3,32m x 1,38m in cinemascope
2 x BR909/Cine9
Each of the projectors would project on a screen of 1,84m x 1,38m (4:3)
So i'll have an edge blend zone of 36 cm in the middle of screen.
cheers
ElTopo
 Filesize:  381.44 KB
 Viewed:  8932 Time(s)
redfox001
PostLink    Posted: Thu Dec 10, 2015 2:03 pm    Post subject: Reply with quote
Wow! that really looks super. Are you using the tvone for blending?
ElTopo
PostLink    Posted: Thu Dec 10, 2015 2:30 pm    Post subject: Reply with quote
I still have those. So each of the tv ones could go for example with 1064 x 800@ 72Hz
Saves bandwidth on each projector and increase sharpness.
Well i still miss a single HD10L lens or a complete set to do the setup.
ElTopo
ElTopo
PostLink    Posted: Thu Dec 10, 2015 2:32 pm    Post subject: Reply with quote
But also do not forget the brightness you'll have with two projectors !!!!! Thumbs Up
redfox001
PostLink    Posted: Thu Dec 10, 2015 2:36 pm    Post subject: Reply with quote
Yes true cinemascope is the way to go. The contrast will be twice and the Cine 9 does resolve that resolution almost perfect so you get almost UHD quality. The phosphor use will also be more even square i think that also give more light.
I have a GT17 set of lenses that I do not use anymore. Can you use those?
ElTopo
PostLink    Posted: Thu Dec 10, 2015 3:14 pm    Post subject: Reply with quote
Thanks for the offer but GT17 are not working with that screen size.
GT17 start at a screen size of 2m in width.
I need HD10L for the blend.
redfox001
PostLink    Posted: Thu Dec 10, 2015 4:54 pm    Post subject: Reply with quote
Will HFQ900 work for a blend? I think they should because they where used in a blend.
Page 5 of 9
