HDFury Version 1 Power Supply Help
PostLink    Posted: Mon Jan 27, 2014 8:20 pm    Post subject: HDFury Version 1 Power Supply Help Reply with quote
Hey guys,
I just sold someone on the forum an HDFUry with a power supply. When I went to test the HDFury before shipping it out I discovered that the PS I have does not actually have the correct output plug (it's slightly too large on the OD). Could someone please tell me the diameter specs on the PS output plug for the HDF version 1?
Is it the same as the HDF2 with + on the sleeve and - on the center pin? What are the diameters I am looking for? I think I am going to have to order the cable. I have plenty of power supplies that will work, but nothing around that has the correct barrel.
Thanks,
JETI 1211 Spectroradiometer
Klein K10-A Colorimeter
PostLink    Posted: Mon Jan 27, 2014 9:18 pm    Post subject: Re: HDFury Version 1 Power Supply Help Reply with quote
CIR Engineering wrote:
Hey guys,
Thanks,
Craig, it's the same plug and polarity as the HDFury2. You can use a power plug from a Nokia phone BUT you must reverse the polarity.
From the FAQ's:
The DC jack on the side of the HDfury must follow all these requirements:
- Provide REGULATED (+/- 5%) 5VDC power with 0.5A min DC current
- Deliver the power through a small 0.65mm diameter center pin / 2.6mm outer diameter DC plug (like the one often used in cellular phone AC adaptor)
-Provide the correct polarity with 'plus' on the OUTER part of the plug and 'minus' (ground) on the small center pin of the DC jack.
Maximum power : 0.4A under 5V (at 165MHz pixel clock)
PostLink    Posted: Mon Jan 27, 2014 9:56 pm    Post subject: Reply with quote
Thanks for the info.
Now where am I going to find one of those phone cords...
Anyone know where I can order just that odd size barrel connector? I have plenty of 5v wall warts, just not the right barrel.
PostLink    Posted: Mon Jan 27, 2014 9:59 pm    Post subject: Reply with quote
Mouser sells them I . I used them for the Radiance Power supply i built.
And radio shack might have the size you want. I also got some from there as well.
PostLink    Posted: Tue Jan 28, 2014 7:56 pm    Post subject: Reply with quote
Does anyone know if this is the correct barrel?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140908584430&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
Thanks,
PostLink    Posted: Tue Jan 28, 2014 9:15 pm    Post subject: Reply with quote
http://ericscorner.blogspot.com/2009/08/not-all-nokia-battery-chargers-built.html
UncleWill
PostLink    Posted: Tue Apr 29, 2014 1:14 am    Post subject: Reply with quote
Nash, using the chart you posted up, can tell me which one I should buy?
The AC3-U seems to be the winner using Analog's criteria:
UncleWill
PostLink    Posted: Tue Apr 29, 2014 1:20 am    Post subject: Reply with quote
P.S. The barrels on these things are more or less the same, right??
UncleWill
PostLink    Posted: Mon Mar 09, 2015 6:52 pm    Post subject: Reply with quote
Okay, having a total n00b moment here. Please be patient with me.
I still haven't taken care of the power supply for this thing, so decided to take of it this weekend. I followed Nash's advice and hit RadioShack. Looks like they had NOTHING close to 500MA at 5V. Neither does their online store.
Last night, I checked out Mouser and found the "flow chart" for ordering stuff. They had the right amperage and voltage, but not the barrel size needed. I have the appropriate plug, courtesy of an old multiplug kit, but just need the right power brick.
Should I just order one with the right electrical rating and just pop on this new head, or go find this Nokia charger?
PostLink    Posted: Tue Mar 10, 2015 1:12 am    Post subject: Reply with quote
Just get the right voltage/amperage and plug the tip in for negative (-)
PostLink    Posted: Tue Mar 10, 2015 1:14 am    Post subject: Reply with quote
Three crucial things:
1) It needs to be a REGULATED 5 volt supply
2) It needs to be 500mA or more. You can go as high as you want amperage wise.
3) The DC plug needs to be the right diameter
and a bonus 4, as Jeremy already says, the polarity needs to be right.
PostLink    Posted: Tue Mar 10, 2015 1:22 am    Post subject: Reply with quote
Since I have the proper USB cord I power it off of the PS3, cable box, ATSC tuner or powered USB hub.
