IR Command input on Radiance 2020 ?
jarseneau
PostLink    Posted: Thu Feb 05, 2015 4:11 pm    Post subject: IR Command input on Radiance 2020 ? Reply with quote
I seem to be doing something wrong in trying to use the IR Command input. I read Lumagen techtip 9 and tried a 3.5 mono headphone plug to the flasher output of a Buffalo electronics IR-100. When connected to the Lumagen, the IR-100 flashes constantly like the lumagen is feeding back resulting in nothing working. Otherwise the IR works fine with a flasher blinking into the 2020's front IR sensor.
I'd there some trick to using the IR Command input jack on the rear?
Jerry
