Francisco
Joined: 05 Apr 2007 Posts: 305 Location: The Netherlands
Link Posted: Wed Dec 03, 2014 10:41 pm Post subject: |
redfox001 wrote: | Did not have the time yet. Hopefully tomorrow. Looks good but if the image has some shaking I am going to replace the connector cable with coax. Just cut the wires and put three peaces coax in between should be easy. |
Did this as well and it's a little extra upgrade. I used RG 179DT Belden cable.
_________________ Philips vacuum cleaner | Trystar double toaster | Car radio with orange plastic memory arrows | Class A Fridge
redfox001
Joined: 16 Mar 2009 Posts: 2251 Location: The Netherlands
Link Posted: Thu Dec 04, 2014 9:46 pm Post subject: |
Ok guys. Short first impressions here. I plugged in the card half an hour ago and am amazed. Decided to write a quick report here now.
It plugged in easy. It was a little difficult to get the hdmi cable in because there is not to much room but it is enough.
Now first. My old hdmi moome card had the problem that I had to start the Barco cinemax first and than start the hdmi source. If I did it in the other order the Max would get in very strange errors and the HV would shut down.
This one works as it should. A lot of led start to talk to each other and after a few second there is an image regardless of what order I start.
Than I found that the image was overly bright and I had to set brightness to 30 on a testimage. I think the default setting of the pots needs some adjustment? The contrast was to high too.
But the image? Amazing!!!! That is why I had to stop watching and write this. It is sharp. Very sharp. Real. Best I ever had. The 1080p one on one showed also the best I had (comparable to a Mac vga adapter with ultra short cable).
But again just first impressions here. After adjusting brightness and warming up I looked at some of my familiar movies and as I said looked very very good. Gave me the feeling that I have a new projector again.
Now I was going to be very honest and critical if that would be necessarily but respect to Moome this is a top card! Wonder if I can get that 3d to work.
Oh and almost forgot I did not see any trembling in the image so even the cable seems to be allright.
redfox001
Link Posted: Thu Dec 04, 2014 11:01 pm Post subject: |
Ok the thing with the brightness was solved by choosing the right video input range.
Link Posted: Fri Dec 05, 2014 1:10 am Post subject: |
redfox001 wrote: | Ok guys. Short first impressions here. I plugged in the card half an hour ago and am amazed. Decided to write a quick report here now.
Oh and almost forgot I did not see any trembling in the image so even the cable seems to be allright. |
Sweet
JETI 1211 Spectroradiometer
Klein K10-A Colorimeter
stridsvognen Guest
Link Posted: Fri Dec 05, 2014 10:24 pm Post subject: |
Any screen shots.?
Francisco
Link Posted: Fri Dec 05, 2014 11:24 pm Post subject: |
Ok what is interesting about this picture?
- don't look at sharpness banding or the funny masks
This is the 1:1 that belongs to it.
- don't look at sharpness, my camera couldn't focus very well and this was shot out of hand.
redfox001
Link Posted: Fri Dec 05, 2014 11:44 pm Post subject: |
stridsvognen wrote: | Any screen shots.? |
I don't have much that will show on testpictures. The one on one looks about the same as I posted earlier. Still there seems more detail, the picture is rocksolid and I don't see noise at all.
But somehow and I have to figure out how the streaking problem is back Might simple be that the voltage shifted when plugging boards.
@Francisco your one on one is way better than mine.
Link Posted: Sat Dec 06, 2014 2:54 am Post subject: |
Francisco wrote: | Ok what is interesting about this picture?
There seems to be some reasonably noticable vertical waves on the left, and the convergence is out a fair bit down that left side.
There looks to be an anomoly down the right hand side of the horizontal 1s 2s and 3s
ElTopo
Link Posted: Sat Dec 06, 2014 8:16 am Post subject: |
The order page is one click away
Francisco
Link Posted: Sat Dec 06, 2014 8:57 am Post subject: |
[quote="CasetheCorvetteman"] Francisco wrote: | Ok what is interesting about this picture?
There looks to be an anomoly down the right hand side of the horizontal 1s 2s and 3s |
That's not what I meant. The image wasn't converged yet or any other adjustments like porch settings.
What I hoped you had noticed is that the aspect ratio is 16:9 and the refresh rate 72hz. So it's displaying 1080p@72hz fully and the 1:1 holds pretty well. Maybe not as good as the Marquee's but still I find it quite awesome. Sharpness is still supurb and it's stable. I'm going to work on the right porch settings for the Barco and will fine tune it.
ElTopo
Link Posted: Sat Dec 06, 2014 6:30 pm Post subject: |
Imaging what a blend will look like with this card
Could you please check 2048 x 1536@60Hz with this card ?
redfox001
Link Posted: Sat Dec 06, 2014 10:13 pm Post subject: |
Few more simple tests. The Moome takes every resolution that I try without problems.
The streaking problem I mentioned earlier turned out to be that the 17 volt shifted somehow. Put it back to 17,7 and solved.
The one on one is better than the former Moome I had but the Barco limits the bandwidth further.
Link Posted: Sun Dec 07, 2014 6:45 am Post subject: |
Francisco wrote: | CasetheCorvetteman wrote: |
What I hoped you had noticed is that the aspect ratio is 16:9 and the refresh rate 72hz. So it's displaying 1080p@72hz fully and the 1:1 holds pretty well. Maybe not as good as the Marquee's but still I find it quite awesome. Sharpness is still supurb and it's stable. I'm going to work on the right porch settings for the Barco and will fine tune it. |
I saw that yes, but I certainly wouldn't have thought that would be the "interesting thing" about those images, I couldn't find anything else note worthy, other than the items I mensioned and items you said to ignore.
Ive used 2560x1600p at 60Hz before, and although it was a bit softer you could still read the text in Windows on the default size.
What is the max resolution you can do with the new MOOME card that you have tried?
ElTopo
Link Posted: Sun Dec 07, 2014 8:27 am Post subject: |
2048 x 1536 into each BR909 for blending would be 4K
stridsvognen Guest
Link Posted: Sun Dec 07, 2014 10:55 am Post subject: |
How do the 5% IRE window look on the 909 with this new moome card.?
Is there someone who can try shoot the 1:1 closeup with different contrast settings, from black to white.?
redfox001
Link Posted: Sun Dec 07, 2014 11:44 am Post subject: |
[quote="Francisco"] CasetheCorvetteman wrote: | Francisco wrote: | Ok what is interesting about this picture?
He you are giving me an idea 1920x817@72 is lower bandwidth than 1920x1080@60. I don't think that is what you mean with the 16/9 but I am going to try 72hz that way the Moome seems to accept all resolutions.
ElTopo
Link Posted: Sun Dec 07, 2014 3:28 pm Post subject: |
Sure it is, just give 817p @72 Hz a try.
Link Posted: Sun Dec 07, 2014 3:46 pm Post subject: |
If you have a VP or HTPC you should always setup 818x1920p 72Hz. Why wouldn't you? It's the best of every possible world; low bandwidth, film multiple for 24Hz playback, sharper, easier on projector...
Moome's card should have no issues with any custom resolutions you want to try. If you have a Radiance 214x or a PLUS model you can probably get away with digital resolutions through about 195 MHz. If you need to run higher clocks for something like 3D (using about 192 MHz on a VP) than it's also possible to increase the voltage to Moome's HDMI chip. Moome tends to set the voltages on the low side of the range considered allowable by Si. I often raise the voltages towards Si's higher allowable range if the chip in hand can't run the clocks I want with Moome's voltage.
It's up to Moome to decide if he wants any info like that floating around though.
