Link Posted: Thu Oct 30, 2014 5:00 am Post subject: Urgent! Need to convert M2TS to AVCHD how? |
I have a 1920 x 1080 24fps video file with 16bit 48Khz audio in .M2TS format and I need to make it go on a DVD in AVCHD format. Anyone know how? I need this fast. ! Halloweens here and I need this yesterday!
Mr. Green
Link Posted: Thu Oct 30, 2014 6:15 am Post subject: |
Any video Converter? Haven't used in years, but worked on translating anything I was converting <aka:porn>.
Kidding, I had a camera with video function that recorded in an annoyingly long <memory eating format when it mattered> that I had to convert to MPEG4 so I could keep taping my sons jolly jumper antics and such. It converted pretty much anything. I don't know if it's current version does... or will do what you want, but worth taking a peek at.
http://www.any-video-converter.com/products/for_video_free/
Funnily, it might have been AVCHD or whatever I was trying to convert out of. Sounds familiar anyways. lol If it is "that format" I hope you have enough memory. so annoying. Even effing quick time was better than that.
It's late and I'm not looking for it, but it spells out somewhere what formats it will translate and I only had the free version which did what I needed. Hope it helps.
_________________ You can be young only once but, you can be immature forever.
Link Posted: Thu Oct 30, 2014 6:20 am Post subject: |
Demux transport stream (m2ts) to program stream (mpg or m2v), then drop that file into Handbrake. Make SD AVCHD file from Handbrake.
Should be able to find a simple app to demux. Some kind of MPEG toolkit. Sorry - not up on windows utils.
Wepener
Link Posted: Mon Nov 03, 2014 5:05 am Post subject: |
Thanks guys but I never did get it onto a disk. Fortunately the OPPO 93 played the M2TS stream right off the USB stick from a class 10 SD CARD. Strange though. The audio was still problematic. It would not fire every time. It was fine once I set an A-B loop on the player.
I'll get back to making a proper 1080P AVCHD bluray formatted DVD+R eventually.
Bucketfoot
Joined: 17 Mar 2006 Posts: 698 Location: Centennial, CO
Link Posted: Fri Nov 21, 2014 10:20 pm Post subject: |
Same post as in the BluRay ripping thread...
Well it's probably overkill for what you want, as I've become the designated family videographer (have done 4 family weddings now), but I use Cyberlink PowerDirector for all of my video editing and disc creation.
If you've got someplace you can upload the file to, I can download it and try to see if it will do what you are looking for.
Siuuu
Link Posted: Fri Aug 04, 2023 9:03 am Post subject: |
To convert a 1920 x 1080 24fps video file with 16bit 48Khz audio in .M2TS format to AVCHD format for a DVD, there are several options available:
WinXDVD: This free M2TS to DVD converter burner can convert HD camcorder M2TS videos to DVD with remarkable quality.
Convertio: This free online M2TS to AVCHD converter allows you to change the format of your video file without the need to download the program.
FoneDog Video Converter: FoneDog Video Converter allows you to convert to multiple output formats, including AVI, FLV, MP4, M4V, MKV, MOV, 3GP, 3G2, SWF, WMV, ASF, AAC, AC3, AIFF, FLAC, M4A, MP3, OGG, WAV, WMA, etc.
DVD Creator Converter: This step-by-step tutorial shows you how to convert and burn High Definition MTS, TS, M2TS videos to DVD disc so that you can enjoy them on a DVD player.
Wondershare DVD Creator: This software can convert and burn MTS/M2TS files to DVD quickly and easily.
All of these options should be able to convert your M2TS file to AVCHD format for burning onto a DVD. However, it is important to note that the conversion process may take some time depending on the size of the file and the speed of your computer.
Link Posted: Fri Aug 25, 2023 8:19 am Post subject: |
Wow I remember this! It like it was just 9 years ago....
Glad people are taking the initiative to help others on the interwebs </sarcasm>
