Link Posted: Sun Sep 14, 2014 4:54 am Post subject: Barco Cine 9/909 SMPS sub board |
Hi all,
Can someone with a Cine 9, CineMAX, or a 909 have a look at their SMPS for me and the little board ( R7631421S-06 is what is on mine ) on the top, what is the value of the two capacitors C450 and C451??
Mine are squealing, they are 560uF 35v
What should they be?
KellenerSptM5
Link Posted: Sun Sep 14, 2014 5:29 am Post subject: Re: Barco Cine 9/909 SMPS sub board |
CasetheCorvetteman wrote: | Hi all,
What should they be? |
That is the correct value for a 909/Cine9. There was a service bulletin issued at some point to make those low ESR caps, but they are the correct values.
Link Posted: Sun Sep 14, 2014 6:03 am Post subject: |
Thanks mate
Yeah I have the service bulletin here stating that, I just pulled it out to have a gander and they are green coloured 560uF 35v, the service manual says 470uF i think.
These have always squealed, id really like to fix that issue...
I thought there was a way to adjust the horizontal position of the rasters too, but I cant find it, the reason I state that is because my blue is quite a way off centered and requires almost all the blue raster shift to line it up with green and red if you want the blue image to remain in the center of the blue tube face...
Link Posted: Sun Sep 14, 2014 10:46 am Post subject: |
Case the horizontal pots should be on the h deflection board. One for red and one for blue
You should be able to see both pots looking down at the card cage.
Link Posted: Sun Sep 14, 2014 2:20 pm Post subject: |
I had a pretty good look, could only find verticals!! They are clearly marked, the others i cant even see.
Link Posted: Sun Sep 14, 2014 10:47 pm Post subject: |
Id say the reason blue is out the way it is will be because the tube is stuffed, id say the gun is out of alignment.
redfox001
Joined: 16 Mar 2009 Posts: 2251 Location: The Netherlands
Link Posted: Sun Sep 14, 2014 10:51 pm Post subject: |
CasetheCorvetteman wrote: | Id say the reason blue is out the way it is will be because the tube is stuffed, id say the gun is out of alignment. |
I never tried but losening the ring on the focus yoke is it possible to shift that yoke and the raster like on a Marquee?
Link Posted: Mon Sep 15, 2014 12:57 am Post subject: |
Unlikely, but thats not the reason for it, my blue tube has internal issues and has done since i got the machine.
KellenerSptM5
Link Posted: Mon Sep 15, 2014 2:25 am Post subject: |
CasetheCorvetteman wrote: | Unlikely, but thats not the reason for it, my blue tube has internal issues and has done since i got the machine. |
PMed you Case.
KellenerSptM5
Link Posted: Mon Sep 15, 2014 3:00 am Post subject: |
PMed you again Case.
Link Posted: Mon Sep 15, 2014 4:07 am Post subject: |
Cheers mate, ill have a look It no longer emails me to tell me now!!
