mookee
Link Posted: Mon Aug 11, 2014 8:40 pm Post subject: nec 6 pg plus ceiling mounting angle screws |
hi.
just starting to install my now first time ceiling mounted nec 6pg plus and as i live in a building with 3,7 meter high ceilings i find the picture is quite too high for me. there are those angle screws on the mountig thing, and i guess i could do the lowest possible angle to get the picture deeper. but isnt there a point in the manual that says something like "not higher then 11degree " or something, and as the tubes got 11 degree as far as i know, wouldnt that be a problem--! thoughts ?))
a ja and by the way, i know my projector got some cap issues, (no i didnt solve them yet.. but why cant i run it on anything higher than 60hz, when the manual tells me about up to 75 hz. as i said before, after a while on power (means being pluged to power, and being used regulary) the pj start working normal and i can run any resolution without greater issues but never more than 60hz so far. would appriciate thouht to that two )
doing the manual step by step guide right now, so i will be here for a while.. just post please...
lg christoph
mookee
Link Posted: Mon Aug 11, 2014 8:50 pm Post subject: |
or in other words, can i compansate the angle the mountig thing actually allows me?.. i would guess so!! but, you know.. help please, am stucked at this issue in my step by step until i know that..
V
mookee
Link Posted: Tue Aug 12, 2014 7:40 am Post subject: |
realy. can i do the highest angle of the mounting thing and will still get a usefull picture, or not. am stucked without knowing :/
hansilili
Joined: 09 Mar 2007 Posts: 302 Location: Köln, Germany
Link Posted: Tue Aug 12, 2014 9:12 am Post subject: |
if you tilt your projector too much you will have geometry and focus issues. It is not a good idea to run the keystone correction maxed out, better stop when you hear a cap humming. Also the focus plane of the lenses and the Scheimpflug adustment will lead to poor focus on either top or bottom of the screen.
What you could do if the projector hangs too high is tilt the screen backwards. But better think of a construction to lower the ceiling mount, e.g. by using some 1 m long truss rods (Schwerlastdübel in die Decke, M6 Gewindestäbe rein und daran die Halteklammer hängen). You can also floor mount the projector.
Use the tilt function of the ceiling bracket only for minor corrections or you will end up with poor alingment/geometry and/or grill the convergence board circuits.
Re the frame rate issue, try reducing the resolution or run an interlaced signal. 1080P at 60Hz is too much for your projector. I mainly run 819 lines at 48 Hz progressive or 1080 interlaced.
Best regards
hansilili
_________________ HansA, alles andere ist euer Bier!
mookee
Link Posted: Tue Aug 12, 2014 9:51 am Post subject: |
hi h.
thanks for your answer. okay, so i guess i will keep it in the basic angle the mounting bracket offers and will try to help myself in another way.. (still asking myself why there is the option of bigger angles in the bracket anyway..but well..may i try it for the hack of it;)
for the 75hz, i run my pj trough a pc, so i figure it doesnt matter what picture rate (prog. or int.) i feed the pj with, as long as i dont go higher than mentioned 1280x1024 75hz on my pc output... so am not shure what you mean.. or do i miss something here??
thank you very much, i was sitting on fire to go on with the installation procedure..)
lg christoph
Link Posted: Wed Aug 13, 2014 7:47 am Post subject: |
Its not the resolution you need to stay within, its the max H scan rate. V scan rate can go alot higher than 75Hz if the resolution is low enough.
Best options for that machine are 1280x720p at 60Hz or 72Hz, or 1920x1080i at 60Hz.
If there are alot of bad caps on the DEF board, youll see issues getting it to sync to some resolutions. My 9PG just plain would not do some resolutions with a clear image, it was all scrambled. It would do most fine, and it would do 1600x1200p at 60Hz without issue. Aussie_Al's 9PG on the other hand seemed to have no problems syncing to whatever res i sent it, it was apparently owned by GregSTV and it seems he had put abit of work into it, where as mine had all the pots on the DEF board played with, making it very hard to get it to operate as it should.
mookee
Link Posted: Fri Aug 15, 2014 9:28 am Post subject: |
hi. why 1280x720? i have choosen 1280x1024 @ 60hz now, as i figured it would be a waste of the 300 horizontal lines otherwise.. bad idea??
btw. i have choosen this resolution because, as my ceiling is very high, i come as deep as can with that 1024 horizontal lines..hmm, not shure if thats true now..;
lg c
Link Posted: Fri Aug 15, 2014 9:42 am Post subject: |
Because 1280x1024 is a 5:4 format, movies are generally in 16:9 format.
mookee
Link Posted: Fri Aug 15, 2014 10:25 am Post subject: |
doesnt the picture get recalculated automaticaly? .. strange thing also is, that circles are in x 1024 real circles without any adjustments and in x720 some kind of eggs..
Link Posted: Fri Aug 15, 2014 10:43 am Post subject: |
mookee wrote: | doesnt it get recalculated automaticaly? |
No.
mookee wrote: | strange thing also is, that circles are in x 1024 real circles without any adjustments and in x720 some kind of eggs.. |
Adjust the amplitude on the projector to get round circles in x720
mookee
Link Posted: Fri Aug 15, 2014 11:34 am Post subject: |
well i guess when playing from dvd and co. through pc or dvd players i can set up the players to get into propper aspect ratio, and some streamplayer can do the trick two.. but in any other cases it would realy suck to have the wrong ratio. also am asking myself what happens if i hock up a ps3.. can it be set up for different the aspect ratios two?
i could just set a second cannel on my pj for the only in 16:9 aka 720 "exeptions".. there arent in fact that many.. .instead of recalibrating the whole pj to 16:9 ratio on 720 now again. i just allready got the centering done and the astigs for the green lenses, based on 1280x1024 @60hz. guess i have to do this again if i reset the whole pj base to 1280x720@ 60hz.. (or is the allready marked center (the 1280x1024 gave me) a propper clue to center the pj tubes @ any ratio, even with tubes on??)
what do u think please?)
Link Posted: Fri Aug 15, 2014 12:16 pm Post subject: |
A memory slot on he NEC is connected to the signal timings, so you need to set up as many memory locations as many resolutions you want to use, but you only have to set up astig and raster centering once as it is a part of the mechanical setup procedure.
I think in the plain PG there is no option to copy convergence data, but in the later models this option makes easier to set up similar resolutions.
Also you can have multiple settings (memory slots) for the same resolution, but the projector will lock automatically whichever is earlier in the list, then you can select the different settings from the input list.
mookee
Link Posted: Fri Aug 15, 2014 12:46 pm Post subject: |
yeah,. its just because the stepbystep says you should decide which resolution you are going to use mainly, BEFORE you do the setup ..and stay with it then... so i was nervous about it. hmm./
thank you )
mookee
Link Posted: Fri Aug 15, 2014 1:45 pm Post subject: |
more or less: "..decide which resolution you are going to use mainly, BEFORE you do the setup" - any additional opinions to that anyway?)
Link Posted: Fri Aug 15, 2014 9:39 pm Post subject: |
Do whatever you like. There is 100 different inputs. Use them all if you want.
mookee
Link Posted: Sat Aug 16, 2014 6:16 pm Post subject: |
good news)
thanks
Link Posted: Sun Aug 17, 2014 8:42 am Post subject: |
No worries
hansilili
Link Posted: Mon Aug 18, 2014 3:23 pm Post subject: |
Re CRT optimized screen resolution and refresh rates and supposing you are capable to unterstand german I recommend to read this
mookee
Link Posted: Thu Aug 21, 2014 5:45 pm Post subject: |
cool danke! das kann ich lesen;))
Mr. Green
