yoko
Link Posted: Sat Aug 16, 2014 10:23 pm Post subject: Meter correction |
Hello
i have a question with chromapure meter Correction button
better to enable this option? it's for Idisplay pro or standard ? or both are good to enable this option
because all settings are 0
if i understand field meter = Idisplay meter
and reference meter is other material ? if i don't have a reference meter , this is possible to use the meter correction?
thank you
yoko
Link Posted: Sun Aug 17, 2014 2:55 pm Post subject: |
ok do you think it 's possible to have a better autocal with EyeOne Display 3 meter ,video projector JVC RS49 and lumagen radiance 9x9x9 calibration device
i'm not a specialist but here my adjustment:
4K eshift disable
preset : natural
6500K
all in RGB Level video (chromapure/VP/Scaler)
Advanced Color Gamut :2
Reference Gamut Rec 709 / dE Methode CIE94
Gamma method 2,2
Matrix size 729 points
Measure post calibration 125-729 colors
oppo is OFF
meter : front projector screen
i disable all corrections with scaler lumagen /video projector
i launch directly auto cal and when it"s finish, i adjust contrast and luminosity with lumagen pattern
here the result: i can't have a better CIE specially for green, other post colors are not perfect with reference color.
i forgot a step?
after autocal do you adjust Advanced Colormanagement or normally you don't have to change any color??
thank you in advance
73.09 KB |
8702 Time(s) |
146.52 KB |
8702 Time(s) |
TomHuffman
Joined: 01 Jun 2010 Posts: 76 Location: Springfield, MO
Link Posted: Mon Aug 18, 2014 2:30 am Post subject: |
yoko wrote: | ok do you think it 's possible to have a better autocal with EyeOne Display 3 meter ,video projector JVC RS49 and lumagen radiance 9x9x9 calibration device
4K eshift disable
preset : natural
6500K
Gamma method 2,2
oppo is OFF
i forgot a step?
thank you in advance | Please send a full calibration report and copy/paste the data in the activity window into a text file and send that too.
Send to support@chromapure.com
To diagnose the problem I need more information.
- Tom Huffman
_________________ ChromaPure calibration software & meter packages at CurtPalme.com discounted prices!
