nVIDIA 3D Vision no go with MOOME V3, Why????
PostLink    Posted: Tue Jul 30, 2013 7:09 am    Post subject: nVIDIA 3D Vision no go with MOOME V3, Why???? Reply with quote
I used the nVIDIA 3D vision set perfectly fine with my XG, this MOOME V3 box is meant to be 3D capable, why is it not working?
It wont allow me to select 3D other than discover glasses. There is no option for generic CRT or DLP link display at all, no matter which driver I use right back to 270. I have also tried both HDMI inputs on the MOOME, neither any different.
Is there something I am missing or is this MOOME V3 being falsely listed as a 3D capable display?
This is annoying to say the least, their website claims it to be capable.
The MOOME is connected via RGB to a Barco Cine 9.
Rolls-Royce
PostLink    Posted: Sun Apr 27, 2014 3:19 am    Post subject: Reply with quote
In case you never found your answer, in order to use the Moome to produce 3D images, the display must be capable of receiving 100 or 120 Hz via its RGB input.
....Royce....
modelaratrod
PostLink    Posted: Wed Jul 16, 2014 11:14 pm    Post subject: Reply with quote
Does the Marquee 8500LC accept 100 or 120 Hz via it's RGB input? I'm looking thru the manual and I only see 15kHz to 130 kHz but it doesn't say what ports or if it's all ports? Is anyone running 3D on there 8500LC? If so how is it?
PostLink    Posted: Fri Jul 18, 2014 1:55 pm    Post subject: Reply with quote
The 8500 can run 3D frequencies (720p 96Hz). The primary negative to 3D on the 8500 will be that it is quite dim. The 9500's are already the dimmest 9" projectors and the 8" machines are quite a bit dimmer.
X-Rite i1Pro2 Spectroradiometer & Spyder Colorimeters for JVC auto-calibration where Klein & Jeti are not applicable
haireez
PostLink    Posted: Wed Jul 23, 2014 11:41 am    Post subject: Reply with quote
Hi Craig,
I'm using Vision 1 and bought your fast phosper tube sometimes back. I'm enjoying watching 3D on my CRT and my setting is 50 for both brightness & contrast. I don't agree when you said that 3D would be very dimmed or Marquee 9" is the dimmest CRT while my setting is only 50 and anything above 60 would be too bright to watch.
My source are; Oppo 103, 3D Fury and goes straight to the projector. Its not running at 960hz, but as high as 144hz!!!
The only setback for 3D Fury is that you can see dark band at the top & bottom edge of the screen and they still haven't resolve it yet. They have mentioned about having new emitter but it does not materialize till now.
OPPO 103 & 3D Fury
 Filesize:  104.31 KB
 Viewed:  10612 Time(s)
2 White Vision 1
haireez
PostLink    Posted: Wed Jul 23, 2014 11:45 am    Post subject: 3D Fury Reply with quote
Brightness setting at 50
 Filesize:  67.06 KB
 Viewed:  10608 Time(s)
2 White Vision 1
haireez
PostLink    Posted: Wed Jul 23, 2014 11:46 am    Post subject: Reply with quote
Contrast setting at 50
 Filesize:  85.28 KB
 Viewed:  10606 Time(s)
2 White Vision 1
haireez
PostLink    Posted: Wed Jul 23, 2014 11:47 am    Post subject: Reply with quote
3D running at 144hz!!!
3D Running at 144hz!!!
 Filesize:  54.56 KB
 Viewed:  10604 Time(s)
2 White Vision 1
haireez
PostLink    Posted: Wed Jul 23, 2014 11:58 am    Post subject: Reply with quote
By the way, marquee 8500 & 9500 using the same boards. The only differences would be 8" or 9" tube. I believe it could also go as high as 144hz.
All the above photos are taken from my Samsung Note 3 and not any professional camera. It might not look good here.
2 White Vision 1
modelaratrod
PostLink    Posted: Fri Aug 01, 2014 6:28 pm    Post subject: Reply with quote
My Moome just showed up now I just need to decide what 3D emitter and glasses to go with?
Any suggestions? What's everyone using?
PostLink    Posted: Tue Aug 05, 2014 6:17 am    Post subject: Reply with quote
Im using nVIDIA, but not with the MOOME. I use it via RGB.
PostLink    Posted: Tue Aug 05, 2014 6:21 am    Post subject: Reply with quote
The Cine 9 goes well beyond that even at 1920x1080, but the MOOME V3 wont got that high.
modelaratrod
PostLink    Posted: Mon Jul 13, 2015 8:40 pm    Post subject: Reply with quote
Now that I have the VDC 9500 up and running I'm going to try 3d, my video chain is HTPC , moomie v3 , 9500. What's needed for some 3d action?
