hjhjr
Link Posted: Sat Jun 14, 2014 4:21 am Post subject: moome fullhd V3 HDMI V1.3 card for Marquee |
I sent My card to Moome to be repaired. He replaced the red DAC. It works with my dishnet at 1080i but when I switch to my Roku at 720P the green tube is overdriven and the picture is washed our green. The remote does not work. Any comment appreciated.
Link Posted: Sat Jun 14, 2014 2:04 pm Post subject: Re: moome fullhd V3 HDMI V1.3 card for Marquee |
hjhjr wrote: | I sent My card to Moome to be repaired. He replaced the red DAC. It works with my dishnet at 1080i but when I switch to my Roku at 720P the green tube is overdriven and the picture is washed our green. The remote does not work. Any comment appreciated. |
It sounds like one of the two sources is not in the correct color space to match it's info frame. My guess is that Dish is using CyCbr 444 and that the Roku is using RGB or the opposite.
You can manually change color spaces in the Moome card to test the theory. If that works than something isn't communicating correctly in your system.
JETI 1211 Spectroradiometer
Klein K10-A Colorimeter
hjhjr
Link Posted: Tue Jun 17, 2014 10:51 pm Post subject: |
I contacted Moome, after several e-mails he said check the IR receiver. I resoldered the IR receiver pins. That solved my problem. The card works normally no more green overdrive after pushing button #4.
