JonFo
Link Posted: Sat Sep 01, 2007 12:01 pm Post subject: Gamma option setup guide |
Since the setup of gamma with the new cards seems to be somewhat of a head scratcher for many people (including myself when I first got the card this week), I decided it would be helpful to my own memory and to the community to document how Gamma controls work on the Moome HD cards.
While I have a Sony IFB-HD card (v1.332), I believe these instructions apply to all the recent vintage Moome Gamma enabled cards (as long as they have the gamma circuit and adjustment screw installed).
I just ran through these again on my G70 to validate, but if there are corrections or other observations, I’d be happy to revise the doc.
Enjoy.
Download |
Filename: |
IFB HD Gamma tuning Process.pdf |
247.88 KB |
Downloaded: |
4955 Time(s) |
David1
Link Posted: Thu May 22, 2014 8:20 pm Post subject: |
I tweaked the contrast control on my card and now what ?
Assuming you own a scope how would someone go and reset the contrast control back to .07mv ? Do you need and extender for the card ?
How can you scope a HDMI card , in old days could scope the RGB with the green pin but how does that happen in this digital world?
Link Posted: Thu May 22, 2014 8:46 pm Post subject: |
David1 wrote: | I tweaked the contrast control on my card and now what ?
How can you scope a HDMI card , in old days could scope the RGB with the green pin but how does that happen in this digital world? |
It's the same thing.
Connect a lead wire to the green pin of your card and run it out the back when you plug the card into the projector. Then feed the card an HDMI signal with a 100 IRE white window on a black background.
Connect the scope to the wire lead from the card. Adjust the contrast so that the white window is 0.7 volts above the black background as seen on your oscope.
JETI 1211 Spectroradiometer
Klein K10-A Colorimeter
David1
Link Posted: Thu May 22, 2014 11:59 pm Post subject: |
THANKS SO MUCH !!! Perfect answers
David1
Link Posted: Fri May 23, 2014 12:36 am Post subject: |
THANKS SO MUCH !!! Perfect answers - but which is green pin?
