Bias question
_in_peace_
PostLink    Posted: Fri Nov 15, 2013 3:49 pm    Post subject: Bias question Reply with quote
Hi!
I am using a Sony G70 and I wonder what the difference is between increasing the brightness and increasing the three bias values? Will it be the same result on the gamma?
and is there a recommended value for bias like on the gain? (start out with blue gain on max)
Thank's!
PostLink    Posted: Fri Nov 15, 2013 7:14 pm    Post subject: Reply with quote
Hello
G2 bias is 400 to 600 volts dc to propel electrons out of the gun, and briteness is a dc level within the video amps driving the guns. Gamma is a low end boost, usually applied to blue, to correct the non-linear response of the blue phosphor. I am sure someone more of an engineer will step in and declare me an idiot Smile
thewolfman
PostLink    Posted: Fri Nov 15, 2013 7:41 pm    Post subject: Re: Bias question Reply with quote
_in_peace_ wrote:
Hi!
Thank's!
Schysta bilder!
Till sist: Trist att matchen blev en förlust, var säker på att vi skulle klara noll-noll. Men icke.
barclay66
PostLink    Posted: Fri Nov 15, 2013 9:12 pm    Post subject: Re: Bias question Reply with quote
thewolfman wrote:
Schysta bilder!
= make photos?
winny
PostLink    Posted: Fri Nov 15, 2013 9:17 pm    Post subject: Re: Bias question Reply with quote
barclay66 wrote:
thewolfman wrote:
Schysta bilder!
= make photos?
=nice photos
Oh, and if you need a crash course in Swedish, there is always mastering Swedish. Freakin' hilarious!
[url]
http://www.google.se/url?sa=t&source=web&cd=2&ved=0CCwQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D66fULfwb2X4&ei=jI-GUr_fNMuZ4gSVqYGQBg&usg=AFQjCNE85PrjKPcqAltx84eepnpl-uXO3A
[/url]
thewolfman
PostLink    Posted: Fri Nov 15, 2013 9:20 pm    Post subject: Reply with quote
http://www.curtpalme.com/forum/viewtopic.php?t=5318&start=940
I meant the photo of the last Swede made Smile
_in_peace_
PostLink    Posted: Fri Nov 15, 2013 11:21 pm    Post subject: Reply with quote
Micke lätt språk faktis! Very Happy (very easy language in fact)
_in_peace_
PostLink    Posted: Sat Nov 16, 2013 6:28 pm    Post subject: Reply with quote
Wolfman how is your G70 going? Any scoop setup yet?
thewolfman
PostLink    Posted: Sat Nov 16, 2013 8:21 pm    Post subject: Reply with quote
Oh, I have a scoop set up to but currently not running due to a little part needed to be changed to keep the voltage from drifting and ruining the tubes prematurely. I should have that part within the next 2 weeks. But is a marquee though.
_in_peace_
PostLink    Posted: Sun Nov 17, 2013 9:50 pm    Post subject: Reply with quote
I have problem with the lowest end of the 16-235. When lifting it the image get a foggy look but the lowest dark gray scale is visible. So its a bit of a compromise what to do. 16-235 and foggy image or 26-235 and a super clear image with real depth in it.
Is this a standard phenomenon on CRT projectors?
AFryia
PostLink    Posted: Tue Nov 19, 2013 12:28 am    Post subject: Re: Bias question Reply with quote
Same but different, brightness is global to the image BIAS is specific to that color. If you want decent gamma without a VP keep the contrast <70.
You can start at the factory recommend however Bias and Gain are unique to every machine. If I recall right my blue is also less than 255.
