Link Posted: Tue Oct 01, 2013 11:15 pm Post subject: |
stridsvognen wrote: | km987654 wrote: | stridsvognen wrote: | CasetheCorvetteman wrote: | I dont hear the projector ever. Its not loud enough for me to hear it. Even when the fans go fast i cant hear it from my viewing seat.
km987654 wrote: | CasetheCorvetteman wrote: | I cant say ive tried that KM, i run mine straight out of the PC at 817p, although never use it for much yet. |
At the moment I am really learning to dislike Moome cards. |
Internals are tollerable. |
From what i understand the time i have been on this site, Moome converters have been the quality must have for CRT.
Now you guys from down under say its garbadge.. Would be nice to know exact what the problems are, and some alternatives that works better.. ??
Maybe there is a reason that Moome never made a Barco Internal card.? Is it possible that Barco projectors is the problem.? |
My comments are in relation to the Moome EXT Fullhd v3 only
The lack of customization available would be a place I would start. These units are built for CRT yet resolutions like 800p or 720p/72 that are commonly used to maximize bandwidth are not supported and there is no pass through that I can see that would allow me to take advantage of what my Lumagen can do.
Dip switch configuration has long since come and gone in almost any technology I have seen yet its still here in the latest generation of Moome.
I will get back to you on image quality as my first impressions may well be influenced by the initial configuration issues I have had so I will let the dust settle and try a few things before comment. I would add that this is not my first Moome Fullhd and I do have a Mux-Hd that works well. |
Now i expect that the EXT moom works as the internal, regarding supporting framerates and resolutions.. maybe not when reading the manual, but think Craig once confirmed it did so.
I can put whatever i want into my Moome.. 800 801 802 803.. whatever comes in my mind whatever framerate i desire, as long its inside the bandwidth.
It have a remote to set color space.. video level.. 100 step gamma.. Whats missing.?
The HDfury3 .. with Dip switsch.. so it looks like thats the way to go these days.
If find a moome EXT ill buy it and test it on one of my Marquee.. |
800p and 720p/72 are not supported in V3 at least check the data sheet and when you try those the Moome will not sync to them. Because someone else uses dip switched doesn't at least to me justify their use.
Download |
Filename: |
ifb_fhdv3_v10.pdf |
2 MB |
Downloaded: |
217 Time(s) |
stridsvognen Guest
Link Posted: Tue Oct 01, 2013 11:21 pm Post subject: |
I think the resolutions mentioned are just highlights..
We do all kinds of different timings, and i never seen anyone here complain that the Moome was the problem there.
What happens when you try to run 800P 72hz on yours.?
stridsvognen Guest
Link Posted: Tue Oct 01, 2013 11:36 pm Post subject: |
km987654 wrote: |
Because someone else uses dip switched doesn't at least to me justify their use. |
Because someone else uses a Barco CRT doesn't at least to me justify their use..
Link Posted: Tue Oct 01, 2013 11:40 pm Post subject: |
Because someone else uses a Barco CRT doesn't at least to me justify their use.. |
What are you talking about?
stridsvognen wrote: | I think the resolutions mentioned are just highlights..
What happens when you try to run 800P 72hz on yours.? |
To answer your question with the Moome in the chain it simply flashes on and off. It does this with 720p/72. The datasheet says these resolutions are not supported. For me there should be a pass through option for those that would be using a VP.
stridsvognen Guest
Link Posted: Tue Oct 01, 2013 11:42 pm Post subject: |
km987654 wrote: | stridsvognen wrote: | I think the resolutions mentioned are just highlights..
To answer your question with the Moome in the chain it simply flashes on and off. It does this with 720p/72. |
Are you sure its the moome..? not the projector.?
Do the projector sync to that resolution without the moome.?
stridsvognen Guest
Link Posted: Tue Oct 01, 2013 11:44 pm Post subject: |
CasetheCorvetteman wrote: | stridsvognen wrote: | km987654 wrote: |
What are you talking about? |
LOL.. If one day, you get the point let me know..
Link Posted: Tue Oct 01, 2013 11:45 pm Post subject: |
stridsvognen wrote: | km987654 wrote: | stridsvognen wrote: | I think the resolutions mentioned are just highlights..
Do the projector sync to that resolution without the moome.? |
No Moome all is good either port 3 or 5.
stridsvognen Guest
Link Posted: Tue Oct 01, 2013 11:53 pm Post subject: |
im running 720P 72hz now no problem clock 95040000.. any resolution works here.. 720P 96hz.. and 84,3hz.. whatever i can emagine
I think you might have some timing isues.
Try these
V total 780
V active 720
V front 5
V sync 5
H total 1694
H active 1280
H front 110
H sync 40
km987654 wrote: | stridsvognen wrote: | km987654 wrote: | stridsvognen wrote: | I think the resolutions mentioned are just highlights..
No Moome all is good either port 3 or 5. |
Correct, works the same in both.
stridsvognen wrote: | CasetheCorvetteman wrote: | stridsvognen wrote: | km987654 wrote: |
LOL.. If one day, you get the point let me know.. |
I got it, but i am wondering why a Marquee owner would be saying it?
stridsvognen Guest
Link Posted: Tue Oct 01, 2013 11:57 pm Post subject: |
I got it, but i am wondering why a Marquee owner would be saying it? |
Then i dont think you got it.. look past the projector brand..
mx83toy
Link Posted: Tue Oct 01, 2013 11:58 pm Post subject: |
CasetheCorvetteman wrote: | km987654 wrote: | stridsvognen wrote: | km987654 wrote: | stridsvognen wrote: | I think the resolutions mentioned are just highlights..
lol
Link Posted: Wed Oct 02, 2013 12:14 am Post subject: |
stridsvognen wrote: | im running 720P 72hz now no problem clock 95040000.. any resolution works here.. 720P 96hz.. and 84,3hz.. whatever i can emagine
Try these
V total 780
V active 720
V front 5
V sync 5
H total 1694
H active 1280
H front 110
H sync 40 |
I will check and see what the Lumagen is outputting and I will use your suggestion if its different.
stridsvognen Guest
Link Posted: Wed Oct 02, 2013 12:20 am Post subject: |
km987654 wrote: | stridsvognen wrote: | im running 720P 72hz now no problem clock 95040000.. any resolution works here.. 720P 96hz.. and 84,3hz.. whatever i can emagine
Try these
V total 780
V active 720
V front 5
V sync 5
H total 1694
H active 1280
H front 110
H sync 40 |
I will check and see what the Lumagen is outputting and I will use your suggestion if its different. |
What Lumagen.?
Bedtime up here, let me know if there is any stuff i can test here that might help you..
Ill be back tomorow..
Link Posted: Wed Oct 02, 2013 12:33 am Post subject: |
stridsvognen wrote: | km987654 wrote: | stridsvognen wrote: | im running 720P 72hz now no problem clock 95040000.. any resolution works here.. 720P 96hz.. and 84,3hz.. whatever i can emagine
Try these
V total 780
V active 720
V front 5
V sync 5
H total 1694
H active 1280
H front 110
H sync 40 |
What Lumagen.?
Ill be back tomorow.. |
Lumagen Vision HDP Pro.
stridsvognen Guest
Link Posted: Wed Oct 02, 2013 5:41 am Post subject: |
Ok, ill get a HDQ here next week i think, so i can give that a shot to.
jbmeyer13
Link Posted: Wed Oct 02, 2013 4:05 pm Post subject: |
stridsvognen wrote: | Ok, ill get a HDQ here next week i think, so i can give that a shot to. |
I run 1920 x 817p/72 from my HDQ through a Moome; no problems.
Link Posted: Wed Oct 02, 2013 7:37 pm Post subject: |
I run all types of resolutions thru the moome when I was experimenting with blend resolutions, the moome took them all like a good little bitch
Those supported resolutions on the data sheet dos not mean that it only accepts those specific ones, it will support anything up to those. I also noticed it will even go a bit higher. I ran 1080p@96 and it acknowledged that on the marquee's info screen.
Link Posted: Thu Oct 03, 2013 12:55 am Post subject: |
I continue to maintain that ive never tried it, or would bother since i removed it from service. I will sell it if someone wants it.
