Barco Cine9 impressions with internal Moome card
Goto page Previous  1, 2, 3, 4 ... 13, 14, 15  Next
PostLink    Posted: Fri Sep 20, 2013 2:37 pm    Post subject: Reply with quote
Ok if you say so, but have calibrated my Marquee's x 2 at least 1000 times and there is nothing you can do to get a flat gamma curve down to 5% white with out raising black. I think I am experienced in this. I did my calibration last night and 5% was at 2.8, 10% at 2.6, 15% at 2.5 , 20% at 2.5 etc etc and 90% at 1.9. With out the radiance or some other gamma correction you can not get a flat gamma curve say at 2.3, 2.4 or what ever. It is the nature of the beast. I do no think there was ever a CRT produced that with out some sort of video processing has got a flat gamma curve.
I have even used a Photo research PR 650 and got the same results. Even with the 03 vim which does not need any line mod fix
it is the same.
Just use the tools given to you in the radiance and be done with with it, your chasing your tail pursuing getting gamma correct in a crt from 0-30. From all my experience over the past 4 years working on my Marquee's I think it is well covered territory.
PostLink    Posted: Fri Sep 20, 2013 2:55 pm    Post subject: Reply with quote
it is the same.
Well im not chasing it, i did it.. And the 03Vim have a elevated pedestal level like the line moddet 02VIM.. the reason i dont use my 03 VIM, it just messes up the low level gamma curve, WHO can be straight as a arow, with no corection. And keep Black Black as the devils ass. Wink
PostLink    Posted: Fri Sep 20, 2013 9:36 pm    Post subject: Reply with quote
The devil's arse is red mate.
the big E
PostLink    Posted: Fri Sep 20, 2013 11:53 pm    Post subject: Reply with quote
Good one case Thumbs Up its true the devil is red Twisted Evil Evil or Very Mad not black unless its a alternate universe Shocked but it ain't Very Happy
crt king of black
PostLink    Posted: Sat Sep 21, 2013 7:23 am    Post subject: Reply with quote
LOL.. To me he lives in a place with no light.. meaning that looking at it you will see nothing but darkness .. Embarassed
PostLink    Posted: Sat Sep 21, 2013 7:31 am    Post subject: Reply with quote
Fire surrounds him, that is a form of light!!
PostLink    Posted: Sat Sep 21, 2013 7:37 am    Post subject: Reply with quote
You have seen to many movies.. Wink Or my Black is red.. Better stop before i get to the point of no return.. lol..
and keep ass out of it next time i want explain my Black level.. Laughing
PostLink    Posted: Sat Sep 21, 2013 7:54 am    Post subject: Reply with quote
Fire is the Devil's only friend according to Don Mclean.
ElTopo
PostLink    Posted: Mon Sep 30, 2013 11:31 am    Post subject: Reply with quote
I see scanlines with 1920 x 800p @72Hz
I think i will go up to 1920 x 800p @96Hz Mr. Green
Barco Cine 9 the one and only
PostLink    Posted: Mon Sep 30, 2013 11:47 am    Post subject: Reply with quote
try look at a 1:1 vertical resolution, and be sure you can resolve both horisontal and vertical before going up..
PostLink    Posted: Mon Sep 30, 2013 12:27 pm    Post subject: Reply with quote
I see scanlines at 1920x1080 72Hz too, but with the PC direct in through RGB i can also see scanlines at 1920x1200, which can be seen with the MOOME V3, when you can get it to let that much through.
PostLink    Posted: Mon Sep 30, 2013 11:52 pm    Post subject: Reply with quote
Just looking at the list of equipment. The Moome won't sync to 800p.
"Oppo BDP-93 (UltimatePlayer) --> Lumagen Radiance XE--> MoomeExt 3 --> The BLEND becomes Barco Reality 909 /w colored C-elements --> Cinemascope screen"
PostLink    Posted: Mon Sep 30, 2013 11:57 pm    Post subject: Reply with quote
I cant say ive tried that KM, i run mine straight out of the PC at 817p, although never use it for much yet.
PostLink    Posted: Mon Sep 30, 2013 11:59 pm    Post subject: Reply with quote
At the moment I am really learning to dislike Moome cards.
ElTopo
PostLink    Posted: Tue Oct 01, 2013 6:34 pm    Post subject: Reply with quote
With 817p@72Hz the noise level on the Cine9 is very acceptable. If you watch a movie you'll not notice it after some minutes.
The fan speed (noise) goes up immediately if you switch to 96Hz.
PostLink    Posted: Tue Oct 01, 2013 8:08 pm    Post subject: Reply with quote
I dont hear the projector ever. Its not loud enough for me to hear it. Even when the fans go fast i cant hear it from my viewing seat.
Internals are tollerable.
PostLink    Posted: Tue Oct 01, 2013 8:30 pm    Post subject: Reply with quote
From what i understand the time i have been on this site, Moome converters have been the quality must have for CRT.
Now you guys from down under say its garbadge.. Would be nice to know exact what the problems are, and some alternatives that works better.. ??
Maybe there is a reason that Moome never made a Barco Internal card.? Is it possible that Barco projectors is the problem.?
PostLink    Posted: Tue Oct 01, 2013 9:22 pm    Post subject: Reply with quote
I know Craig highly recommends the Sony Moome card. I wonder if he has tested the external unit.
PostLink    Posted: Tue Oct 01, 2013 10:04 pm    Post subject: Reply with quote
My comments are in relation to the Moome EXT Fullhd v3 only
The lack of customization available would be a place I would start. These units are built for CRT yet resolutions like 800p or 720p/72 that are commonly used to maximize bandwidth are not supported and there is no pass through that I can see that would allow me to take advantage of what my Lumagen can do.
Dip switch configuration has long since come and gone in almost any technology I have seen yet its still here in the latest generation of Moome.
I will get back to you on image quality as my first impressions may well be influenced by the initial configuration issues I have had so I will let the dust settle and try a few things before comment. I would add that this is not my first Moome Fullhd and I do have a Mux-Hd that works well.
PostLink    Posted: Tue Oct 01, 2013 11:02 pm    Post subject: Reply with quote
Now i expect that the EXT moom works as the internal, regarding supporting framerates and resolutions.. maybe not when reading the manual, but think Craig once confirmed it did so.
I can put whatever i want into my Moome.. 800 801 802 803.. whatever comes in my mind whatever framerate i desire, as long its inside the bandwidth.
It have a remote to set color space.. video level.. 20 step gamma.. Whats missing.?
The HDfury3 .. with Dip switsch.. so it looks like thats the way to go these days.
If find a moome EXT ill buy it and test it on one of my Marquee..
Page 3 of 15
