Bill Roberts
Link Posted: Tue Jul 16, 2013 5:49 am Post subject: Will this configuration work? |
I am considering purchasing the 3D-Theatre PLUS. Does anyone have experience to know if this configuration will work?
PS3 >> Denon AVR-4308CI >> 3D-Theatre PLUS >> Mitsubishi HC7000
I also have
Tivo >> AVR >> VIP >> HC7000 in mind.
Bill Roberts
Link Posted: Thu Jul 18, 2013 8:04 pm Post subject: |
Going to give it a try. I'll keep the forum posted on my results.
Jorrel
Link Posted: Fri Aug 02, 2013 8:06 am Post subject: |
Kal I bought the displayer unit 2 years ago, I want to buy the theatre plus unit will the emitter which I have connected on my displayer unit work for this unit.
Bill Roberts
Link Posted: Fri Aug 02, 2013 1:23 pm Post subject: |
I was unable to connect in the recommended order:
because the AVR-4308CI does not support 3D pass-through.
I connected it as:
PS3 >> 3D-Theatre PLUS >> Denon AVR-4308CI >> Mitsubishi HC7000 instead since the AVR-4308CI is the audio controller for the 7.1 speaker system. This means I can't use the TiVo as a 3D input but it doesn't actually provide anything I can't get through the PS3 other than a broadcast antenna connection.
I am getting satisfactory 3D with some minor artifacts using a 3 blue, 1 red setting on the emitter. The projector isn't using the 120 vertical synch rate, so brightness becomes an issue with any higher red settings (they clean up the 3D quite a bit).
All in all, I am satisfied for now, but I see the necessity of 3D pass-through in a couple of years when I was anticipating getting a new receiver.
Jorrel
Link Posted: Sat Aug 03, 2013 2:08 am Post subject: |
kal wrote: | Jorrel wrote: | Kal I bought the displayer unit 2 years ago, I want to buy the theatre plus unit will the emitter which I have connected on my displayer unit work for this unit. |
Yes. All of the 3D boxes have the same 3-pin DIN connector for the emitter.
The Theater PLUS is here: http://www.curtpalme.com/3DTheatrePlus.shtm
Kal |
Can i buy it from consignia they have a special on the unit....
Jorrel
Link Posted: Sat Aug 03, 2013 2:34 am Post subject: |
Hi Kal I just placed my order via Pay Pal...The payment goes to consignia..
Link Posted: Sat Aug 03, 2013 2:41 am Post subject: |
Thank you for your order - it's appreciated! The payment does indeed go to Consignia but we do get a small percentage here at CurtPalme.com at the end of the month at no additional cost to you (we work with them closely). It's what keeps our website running.
Most of our 3D products ship within 1-3 business days. Our free shipping does not include tracking but it usually takes about 10-14 business days on average to reach anywhere in the world.
Cheers!
Jorrel
Link Posted: Fri Aug 23, 2013 7:43 am Post subject: |
kal wrote: | Thank you for your order - it's appreciated! The payment does indeed go to Consignia but we do get a small percentage here at CurtPalme.com at the end of the month at no additional cost to you (we work with them closely). It's what keeps our website running.
Cheers!
Kal |
Hi Kal,
I got it thanks for your prompt service:
I have question for you in the video chain where would I place the 3d theatre model...
Currently my set up is a PS3 Denon 1.3 receiver connected to my Panasonic plasma screen.
fragzero
Link Posted: Fri Aug 23, 2013 7:51 am Post subject: |
From the specs
INPUT: 1 x HDMI v1.4a (HDCP Compliant)
OUTPUT: 1 x HDMI v1.3 (HDCP Compliant), 3-pin mini-DIN Sync Out (for optional emitter)
Seems the only working spot would be between your source device and reciever.
Source ----- 3D-Theatre ---- reciever
Jorrel
Link Posted: Tue Dec 24, 2013 5:37 am Post subject: |
Kal I hooked up my theatre plus everything works fine sound picture all coming through successfully, but the issue I have is that dialogue is very faint and you cant hear it. have you got any suggestions?
I got around it by changing the audio option on the PS3 LCM to bitstream, the sound is no longer 7.1 but DTS 5.1...but atleast the dialogue is clear. I would still like some help on the issue thank you.
Link Posted: Tue Dec 24, 2013 2:30 pm Post subject: |
How do you have everything hooked up from source to display?
Normally you put your 3D-Theatre box right before the display so the sound has already been extracted. Like this:
Source -> HDMI cable -> Receiver or preamp -> HDMI cable -> 3D-Theatre box -> HDMI cable -> Display
If you have the 3D-Theatre before the receiver/preamp, the audio simple simply passes through.
The Theatre Plus supports 7.1 audio. Note that this 7.1 audio support is not important if the signal passes through a receiver first and the video is passed through to the 3D-Theatre PLUS. It’s more about future-proofing. The HDMI signal is not altered/changed in any way (no conversion).
Jorrel
Link Posted: Tue Dec 24, 2013 9:55 pm Post subject: |
kal wrote: | How do you have everything hooked up from source to display?
Kal |
I hooked it up this way Source ----- 3D-Theatre ---- reciever
Merry XMAS and happy new year...
Jorrel
Link Posted: Tue Dec 24, 2013 10:14 pm Post subject: |
kal wrote: | Try putting the 3D-Theatre after the receiver.
Kal |
OK, I will try it later, do you think it has something to do with the reciever is not a 3d rec.
There is no issue KAL I watched superman in 3d and it looked fantastic all I did to fix the problem is changing the audio single to bitstream...
