dturco
Joined: 06 Feb 2009 Posts: 3779 Location: Eastern Shore Maryland
Link Posted: Sat Feb 09, 2013 6:42 pm Post subject: Beveled edge aluminum framing? |
Ok so I want to build a new 2.37 to 1 screen. I want to use beveled edge aluminum like CARADA does. Only thing is I can't find the framing after 2 days of searching online. I can find, C channel, U channel, T-slot, box frame, I beam, extruded, flat , boxed, Ad infinitum,
Anyone know where to get this stuff? The Criterion series 3 1/4" frame.
Carada link http://www.carada.com/Projection-Screen-Comparison.aspx
http://www.hulu.com/firefly
zaphod
Link Posted: Sat Feb 09, 2013 8:18 pm Post subject: |
picture frame shops?
jeffslife
Link Posted: Sun Feb 10, 2013 4:32 am Post subject: |
Its extruded spec aluminum. They own it. Its not standard.
_________________ We are ALL job creators !
Link Posted: Sun Feb 10, 2013 5:45 am Post subject: |
Wonder if you can fake it with two pieces of extruded aluminium?
Link Posted: Sun Feb 10, 2013 2:49 pm Post subject: |
Then he'll need to bond them in such a way that they do not come apart or rattle. That's a lot of work to skirt an already available market solution.
kabuby77
Link Posted: Mon Feb 11, 2013 10:09 am Post subject: |
You could make the screen with wood and later cover the face with a bended aluminium foil.
Link Posted: Mon Feb 11, 2013 3:34 pm Post subject: |
I had the same problem when I built my screen, so what I did was use "ranch" trim. It was probably more like 2-1/2" wide, but cost was minimal. The ranch trim was from Lowe's or Home Depot, and was less than $10 each for 3-4 pieces. I glued and nailed a 'nailer' strip along the back of each one. Then, I bought 3 yards of stretchy black velvet and cut, stapled, and wrapped each of the four mitered pieces, and nailed it to the edge of my MDF/Wilsonart DW screen.
I think, all-in, my total cost was probably $50 or $60 for the train, on top of maybe $150 for the screen. In the end, I'm glad I didn't spend $250 just on the aluminum, because now I'm thinking about changing my screen.
You can't see it very well, but here it is finished. I can snap a couple of pics if anybody is interested.
http://www.curtpalme.com/forum/album_page.php?pic_id=1210
