mikeshole
Link Posted: Wed Jan 09, 2013 12:43 pm Post subject: Did changing my raster break my projector? |
1292, I squeezed the vertical a bit, but it ran fine for a few days. Then I connected a new computer to it, so a new resolution, and the picture kept collapsing into itself and stretching out, twitching horizontally mostly. Then it just went out and gave me an error 02. Does this hint that a protection circuit is blown? Is it on the E board?
Link Posted: Thu Jan 10, 2013 4:10 am Post subject: |
Hmmm....
The twitching i wouldve attempted to correct by cleaning all the yoke connectors. Not sure if thisll be your issue though.
Careful with that collapsing, youll burn a line into the tubes.
Phoenixed
Link Posted: Thu Jan 10, 2013 5:29 am Post subject: |
Could it be a clamp setting?
_________________ Planar PD-8150/Runco LS-5
mikeshole
Link Posted: Sat Jan 12, 2013 10:49 pm Post subject: |
Phoenixed wrote: | Could it be a clamp setting? |
I'm not sure what that means or how to check. I tried googling it.
Link Posted: Sat Jan 12, 2013 10:54 pm Post subject: |
In the menu, there's a video clamp setting. You can cycle through ( if I remember ) 3 settings.
Page 87 (E) of the install manual:
http://www.curtpalme.com/docs/Sony1292_Install.pdf
69.43 KB |
2783 Time(s) |
mikeshole
Link Posted: Sun Jan 13, 2013 12:15 am Post subject: |
Oh, no. I mean I can't even turn the projector on. It turns off after 2 seconds and gives me an error 02. No video source is plugged in at all.
Link Posted: Sun Jan 13, 2013 12:52 am Post subject: |
No, nothing you did caused this. It's a 17 year old projector!
It's the H output board that needs repair most likely. Answering your PM in a second.
Link Posted: Sun Jan 13, 2013 1:01 am Post subject: |
Curt, is the 1292's H output board like the G70's PA board? Seems like on many occasions I recall guys' G70 PA boards dying after they did geometry or convergence. Just wondering if it was a similar deal.
Link Posted: Sun Jan 13, 2013 2:18 am Post subject: |
No, it's more like the other 12XX series.
