AVphile
Joined: 02 Dec 2008 Posts: 331 Location: Ottawa, Ontario
Link Posted: Wed Nov 07, 2012 5:30 am Post subject: Barco 120MHz neck board streaking |
I have the 762721 boards with Sony tubes in my BG808s and 1 of the 3 is streaking. I swapped boards and the problem follows this one board so I'm certain.
I thought these boards had the high speed parts that wouldn't streak. Not sure what chip to look for ... There is SK6 357 on this one and the other two have slightly different numbers. Or maybe it's just bad.
I'm running it at 67.7kHz if that matters.
_________________ AVStefan
HDFury3 -> BG-808s -> HD-145
Link Posted: Wed Nov 07, 2012 6:45 am Post subject: |
Once I had a streaking issue with my NEC and it was a timing issue, not sure, but you might try different timings, maybe one of your neckboard is hyper sensitive.
Also I think streaking is not a bandwidth related thing, it is a "clamping" issue, which could be due to a deffective part or bad construction.
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
Link Posted: Wed Nov 07, 2012 9:03 am Post subject: |
R762721 is very common board.
I think that Curt certainly have a lot of these boards.
I suggest to buy a set for spare.
The board have two section: the PCB are tube's related (different by tube's type).
R762721 = Sony 8"
R762746 = Panasonic 8"
R762839 = Panasonic 9"
The other section (with black heatsink) instead is common at different types of PCB and have video chip Sanyo VPH08 or VPJ08.
_________________ Domenico (Barco fan!)
Ile
Link Posted: Wed Nov 07, 2012 10:13 am Post subject: |
Probably some chip is going bad or someone have messed calibration from trimpots.
If it's chip related I guess it's bad Sanyo VPH08/VPJ08 or something ABL related.
Used neck boards are pretty cheap, so it's probably not worth to try find -97 discontinued VPH08/VPJ08 that would cost shipped from Asia about same or bit less what used neck board.
I have sourced few VPJ08 years ago from korean forum member, but not really interested to sell.
Link Posted: Wed Nov 07, 2012 2:29 pm Post subject: |
I've got buckets of them... (the boards, that is).
AVphile
Link Posted: Wed Nov 07, 2012 3:02 pm Post subject: |
Ile wrote: | Probably some chip is going bad or someone have messed calibration from trimpots. |
Curt Palme wrote: | I've got buckets of them... |
Is it possible to get a set that is matched in case someone has messed up the trimpots or the boards are different vintage? The set has always been difficult to calibrate. I tried many different ways to set G2 with bizarre results. Using the menu controls I run out of adjustment range before achieving a good greyscale.
Thank you.
AVphile
Link Posted: Wed Nov 07, 2012 9:11 pm Post subject: |
Can they be matched for gain and bias?
Ile
Link Posted: Thu Nov 08, 2012 8:58 am Post subject: |
Amps 200V line, gain (2.35Vpp/100Vpp) and ABL led are calibrated same way.
Pots are locked with varnish in factory, so if varnish are intact those should be pretty close even after 15 years.
ABL led adjustment tend to drift bit though.
AVphile
Link Posted: Thu Nov 08, 2012 3:05 pm Post subject: |
I guess I should not obsess over it and just replace the streaking board, as long as part numbers match. Any idea what R762721-02 is all about?
AVphile
Link Posted: Tue Nov 13, 2012 6:50 pm Post subject: |
Damn streaking!
Watched The Hunt For Red October which is a dark movie and the nasty streaking appeared several times. Very distracting and aggravating after spending the time to upgrade to an 808, rebuild the failed power supply, and tweak it to almost perfect calibration.
Curt - I am one board away from true bliss... I hope you can find me a board in your parts bucket
AVphile
Link Posted: Tue Jan 15, 2013 5:18 pm Post subject: |
Ile wrote: | Amps 200V line, gain (2.35Vpp/100Vpp) and ABL led are calibrated same way.
ABL led adjustment tend to drift bit though. |
I had a few boards out on the bench and measured the pots... they are all over the map, no idea what's right. I realize the entire circuit needs to be considered, not just the pots... so does anyone have a procedure to calibrate them? I don't mind shipping them off somewhere!
The problem is my greyscale is still all over the place. I end up with R-CUT 99, G-GAIN 75, and drastically changing the R-MID & B-MID to get a 2-point greyscale but then gamma is rediculous 1.4
On the positive side, the streaking is gone
