MissMayI
Link Posted: Sat May 26, 2012 5:47 pm Post subject: Xbox 360 to Barco Graphics 801s via vga |
I want to set up my 360 on my projector I have VGA coming out of the 360 so I was wondering if I plug it in to my port4/5 RBGHV will that work? I have the VGA to RBGHV cord so all I'd need is a male to male VGA adapter right?
Link Posted: Tue May 29, 2012 2:36 pm Post subject: Re: Xbox 360 to Barco Graphics 801s via vga |
MissMayI wrote: | I want to set up my 360 on my projector I have VGA coming out of the 360 so I was wondering if I plug it in to my port4/5 RBGHV will that work? I have the VGA to RBGHV cord so all I'd need is a male to male VGA adapter right? |
Hello MissMayI,
Yes you should be able to do exactly that, you will have to setup the PJ though for the 360s resolution, unless you set the resolution to a size that the projector is already configured for.
Otherwise yeah thats about it, pretty easy to do. Hope this helps!
barclay66
Link Posted: Tue May 29, 2012 3:06 pm Post subject: |
The Barcos are a little bit picky when it comes to sync signals. They work best with negative polarity sync. It could be necessary including a sync inverting circuit for the H-Sync and/or V-Sync line. This thread might help: http://www.curtpalme.com/forum/viewtopic.php?t=29569
Regards,
barclay66
