Joined: 25 Aug 2008 Posts: 2479 Location: Chicago USA & Berlin Germany
Link Posted: Mon May 07, 2012 3:24 am Post subject: |
| Curt Palme wrote: | I'm sure Craig is right about the short HDMI cables, but with the little experience I have with short HDMI cables, I've never had a problem.
Just FYI. |
Usualy shorter HDMI cables work fine. However, when trouble shooting a system that isn't working, than using 6' cables is a really good place to start.
I use 1.5' HDMI cables in my own system and they work fine. But with HDMI every installation has its own challenges.
jeffslife
TV/Projector: Sony G90 with moome board V2 ,Marque green C element, Professionally calibrated by CRAIG ROUNDS
Link Posted: Fri May 11, 2012 10:39 pm Post subject: |
OK well part of my monoprice order came today, the 6 foot cables made it so I installed them. No change. I do get a lumagen message that comes up for a second. The image projected is huge, at least 2 foot higher than the normal 16 9 image.( I call it an image but its really just a large screen of static.)
Since I am getting a lumagen message(however briefly) can I assume that it is being sent through to the pj ok ?
I am at a loss, I dont have the repeater yet or I would try that.
_________________ We are ALL job creators !
Joined: 08 Mar 2006 Posts: 18193 Location: Langley, BC
Link Posted: Fri May 11, 2012 10:42 pm Post subject: |
OK, what happens when you go BluRay to projector?
Then put the Lumagen in with another short 6' cable.
Then the receiver.
When you do lose the signal?
jeffslife
Link Posted: Fri May 11, 2012 10:48 pm Post subject: |
Let me give that a shot, be back in a few minutes.
Link Posted: Fri May 11, 2012 11:26 pm Post subject: |
Jeff,
If you haven't tried it yet, hook the Lumagen to the projector with just a 6' cable.
The Lumagen will be defaulted to 480p which is why you are getting the huge image (480p isn't setup on your machine). You can go through the Lumagen menu and change the output to 1080p, or look in the manual for the direct command to enable 1080p.
With a 6' cable at the projector you want to be able to see the Lumagen menu.
If it still doesn't work, make sure the Lumagen and projector are plugged in on the same AC power circuit. If you have the projector and Lumagen (and other equipment) on different circuits you can get a ground loop which the Vision processors are very sensitive to. Have all your equipment on the same circuit.
You also should just remove the ground from the Lumagen 3-pin power cord. Just rip it off with a pair of pliers and get rid of it. Don't use a 3 prong power cord with the Lumagen.
jeffslife
Link Posted: Fri May 11, 2012 11:30 pm Post subject: |
Sorry for the delay, my dog was in a battle to the death with a groundhog. I had to go get her by passing through 30 yards of poison ivy. Then I got stung by yellow jackets(3 times) then a shower. Then I tried your suggestion. When going from the Oppo to the pj FINE.
Then I added the VP and I got a picture but it was full of noise.
Link Posted: Fri May 11, 2012 11:32 pm Post subject: |
I'd say the Moome card is fine, but the Lumagen settings either are off, or the unit (or power supply) is bad.
jeffslife
Link Posted: Fri May 11, 2012 11:35 pm Post subject: |
Going to remove the ground from the VP be right back.
Link Posted: Fri May 11, 2012 11:37 pm Post subject: |
| Curt Palme wrote: | | I'd say the Moome card is fine, but the Lumagen settings either are off, or the unit (or power supply) is bad. |
No, I promise you it is fine. This is not atypical in first installation with a Vision processor.
Most likely you have a cable mismatch between the Lumagen and Moome. By mismatch I just mean that the Lumagen doesn't like the cable.
Try removing the ground pin first from the power plug. If it's no better try the BD and Lumagen under the projector with just 6' cables at 1080p 60Hz from the Lumagen and 1080p 24Hz from the BD.
If that works, try the HDMI extender right before the Moome with your long cable.
If that doesn't work try a new HDMI cable. Get the 22 awg silver plated copper HDMI cable from Momoprice.
But I am sure the Lumagen is fine. You'll get it, or I will
Link Posted: Fri May 11, 2012 11:42 pm Post subject: |
Jeff,
Be sure that you BD player is not set to 1080p 60Hz. If it is you may or may not get a picture from the Lumagen on screen. If you do get a picture it will have noise.
Be sure to set the BD to 1080p 24Hz.
Link Posted: Fri May 11, 2012 11:47 pm Post subject: |
Jeff,
Also be sure to set the Oppo to RGB and make sure deep color is turned off!
jeffslife
Craig, If its ok with you I will just put it back the way it was WITHOUT the lumagen. I dont need it right now anyway.I will order that cable and will have the repeater here by then. Pulling the ground did get rid of most of the noise but not all of it.
OK ?
jeffslife
Link Posted: Fri May 11, 2012 11:48 pm Post subject: |
Set at RGB with deep color off
jeffslife
Link Posted: Fri May 11, 2012 11:52 pm Post subject: |
I am not walking so great right now, my calf is swelling up from the damn yellow jacket stings, maybe I can give this a shot tomorrow.
jeffslife
Link Posted: Sat May 12, 2012 12:02 am Post subject: |
Tomorrow I will set the oppo and lumagen under the PJ and see what happens, I might have to go to the hospital now.
Link Posted: Sat May 12, 2012 12:30 am Post subject: |
Damn dude, get outta here!
Joined: 12 Jan 2007 Posts: 12993 Location: West Seneca NY
AnalogRocks Moderator
Joined: 08 Mar 2006 Posts: 21088 Location: Toronto, Ontario, Canada
Link Posted: Sun May 13, 2012 5:47 am Post subject: |
| Nashou66 wrote: | I guess i Shouldn't complain working 15 hour days and no day off since Christmas, it keeps me away from poison Ivy and Jellow jackets!!
Nashou |
Awww C'mon Nash, there's always room for Jellow.
jeffslife
Link Posted: Mon May 14, 2012 4:20 pm Post subject: |
So I am back at this again. checking settings. The 1080P 24 output is set to off (on the oppo BD) If I set it on ON the image just rolls.
Link Posted: Mon May 14, 2012 6:31 pm Post subject: |
| jeffslife wrote: | | So I am back at this again. checking settings. The 1080P 24 output is set to off (on the oppo BD) If I set it on ON the image just rolls. |
You all right?
Yes, if you set to 24Hz while connected to the G70 the image will roll. Set the Oppo to 1080i 60 Hz and confirm. Then power off the Oppo. Then connect the Oppo to the Lumagen and then set the Oppo to 1080p 24Hz while the Lumagen is set to output 1080p 60Hz.
