Video software to split large .TS files
PostLink    Posted: Mon Mar 12, 2012 8:48 pm    Post subject: Video software to split large .TS files Reply with quote
I have a bunch of 1080i .TS recordings that I need to split ( 2 shows back to back ) they are 15.67GB.
MPEG2VCR won't open anything larger than around 9GB
Do you guys know of a program that can do this, chop the shows in two and edit out the commercials and NOT have to do a 20 hour re-render of the video to save it. Also it needs to be saved as .TS MPEG2
That's what I like about MPEG2VCR, it can save a 44 minute edited 1080i .TS file in about 6 minutes. No re-rendering just snip and join.
Any suggestions?
PostLink    Posted: Mon Mar 12, 2012 8:57 pm    Post subject: Reply with quote
I used to use VideoRedo all the time back when I used to archive lots of OTA stuff. It will definitely edit and save transport streams, and do cuts-only I-frame editing.
http://www.videoredo.com
They have a trial version so you can give it a whirl.
PostLink    Posted: Mon Mar 12, 2012 9:09 pm    Post subject: Reply with quote
Thanks,
I'll have a look.
PostLink    Posted: Thu Mar 15, 2012 6:25 am    Post subject: Reply with quote
Thanks,
I'll have a look.
Downloading now..................
HighDefMike
PostLink    Posted: Fri Mar 16, 2012 6:29 pm    Post subject: Re: Video software to split large .TS files Reply with quote
Any suggestions?
Do you have or have you tried HDTV2MPEG2 ?
I've used it to "join" my MyHD .ts files (it allows you to save them as .tp, .ts, or mpeg2). It should allow you to split them the same way. I'm not aware of any size limitations, but then again, I've never split anything as large as 16GB.
hansilili
PostLink    Posted: Wed Sep 12, 2012 1:55 pm    Post subject: Reply with quote
Hi I use TSsniper tu cut out the commercials from TV recorded .ts files. Works perfect for me.
