bone
Link Posted: Tue Mar 06, 2012 8:48 am Post subject: |
Ordered and waiting...
Is this compatible with Sony 3D glasses TDG-PJ1 & transmitter TMR-PJ1?
Operating Instructions for Sony 3D Sync Transmitter TMR-PJ1 |
Download |
Filename: |
TMRPJ1_EN_ES_FR.pdf |
1.02 MB |
Downloaded: |
3034 Time(s) |
Link Posted: Fri Mar 09, 2012 2:19 pm Post subject: |
Update: Moome emailed back late last night. He tells me the cards will start shipping this weekend so I've indicated that the new ship date is Monday March 12, 2012. Sorry for the delays.
Cinema_mad/Bone: Any Infrared (IR) Active Shutter glasses or Radio Frequency (RF) Active Shutter glasses that include an emitter will work with the IFB-FULLHD v3 card as long as the emitter has the standard 3-pin DIN connector.
RF glasses are generally preferred since they are not affected by line of sight issues. These ones here also have a ton of adjustment options:
cinema mad
Link Posted: Fri Mar 09, 2012 11:41 pm Post subject: |
As always Thanks for your help Kal,
Like many here I have purchased all Moome's previous generations of internal cards
I will now doubt puchase one of these new v3 gen cards when the positive user reviews start flowing..
Jase...
bone
Link Posted: Tue Mar 13, 2012 8:38 am Post subject: |
I just received IFB-v3 shipped from Taiwan, but unfortunately I don't have any 3D emitter/glasses yet.
According to the manual, Sony TMR-PJ1 emitter has a LAN type connection slot that doesn't fit to IFB-v3 card.
And... Many thanks to Kal for helpful guide.
kabuby77
Link Posted: Tue Mar 13, 2012 9:16 am Post subject: |
Let's go with tests!
cinema mad
Link Posted: Thu Mar 15, 2012 11:46 pm Post subject: |
Any one out there upgrading from the V2 ? & or planing on comparing the two,
Just wondering how much if any jump in image quality there is ..
bone
Link Posted: Tue Mar 20, 2012 3:08 pm Post subject: |
Today IFB-v3 card was installed to Sony G70. The 2D image is just fine, but the 3D image is continuously shifting vertically.
I have no ideas what's wrong. I guess this can be a sync problem and I tried with the supplied remote pressing "D" & "Display" keys, but it doesn't help. The manual says "(step 6) ... the projector should be synced", but what this means and why this process is needed? How can I sync the PJ?
Of course, 1080p24 display option of the player is set "off", and I used high-speed HDMI cable (display output directly connected to the PJ). Also The PJ was set as the input: RGB and input clamp: H/C.
Tested source players: Sony PS3 & Oppo BDP-95 /Disc: Tangled Blu-Ray 3D
Any comments will be appreciated.
Screenshot from G70 + IFB-v3 |
147.57 KB |
28857 Time(s) |
tanwn
Link Posted: Tue Mar 20, 2012 11:11 pm Post subject: |
wow, does this mean that this V3 can do without any scaler? That means can use any 3d blu ray player and you can generate 3d on crt? Is the resolution 1080P? If so that is very good news.
kabuby77
Link Posted: Wed Mar 21, 2012 8:10 am Post subject: |
No, you need a scaler and use 720p @ 100 or 120hz for 3D. You can't use 1080p for 3D cause moome max refresh is 75 Hz and however crt does not have enough bandwidth.
bone
Link Posted: Wed Mar 21, 2012 3:58 pm Post subject: |
Oops! I was so excited to hear that the old CRT PJ can display 3D images. But this can not be done with IFB-v3 card alone. I missed a crucial information that the CRT PJ requires a video processor such as Lumagen Radiance 3D series for capable of 3D display. Another frustration... but there is still a chance!
Link Posted: Mon May 28, 2012 3:34 pm Post subject: |
HDMI card overstock sale
Moome needs to clear some overstock of HDMI cards for CRT projectors so he has cut prices to blow them out fast.
If you're looking at adding HDMI to your CRT projector, now's the time to do it! An HDMI input is required to use most of the latest sources such as DVD/Blu-ray players, PS3, and satellite/cable.
Some older card versions are also available in extremely limited quantities. While we recommend the latest version for high end 8-9" CRT projectors, with lower end 7-8" units the difference will not be as noticeable so this is a good chance to save a few dollars.
Quantities are limited. First come, first served. For complete details see the respective order pages listed above.
Questions? Post here or email us at Moome@CurtPalme.com
GREG1292
prover
Joined: 07 Nov 2008 Posts: 166 Location: Stuttgart, Germany
Link Posted: Tue Oct 02, 2012 2:25 pm Post subject: |
GREG1292 wrote: | If I buy a card can I use my HTPC for 3d a Nvidia setup and if so how
would that work? Does it work with my setup? Think I found my amswer
and that would be no. |
you better bet! It works! I have a similar setup: HTPC with nvidia 3dvision, Moome EXT V3, SONY 1292, if your PJ manages the vertical frequencies (100 respectively 120 Hz) then everything is fine for 3D.
Cheers!
_________________ http://www.bluray-disc.de/blulife/heimkino/prover
alank
Link Posted: Tue Nov 27, 2012 7:13 pm Post subject: |
Kal whats the difference between the Sony V2 and V3 card?
EricO
Joined: 22 Mar 2007 Posts: 29 Location: Madison, Wisconsin USA
Link Posted: Mon Jan 14, 2013 9:17 pm Post subject: |
This may be a stupid post, but I've got a Moome card (shipped May 2010) for my G70. Due to circumstances beyond my control (okay, maybe not BEYOND my control. I've been busy!),I've just plugged it into my machine today and I've gotten absolutely nothing. There is probably something major that I've missed. Is there a step by step guide on how to get this card to function? The one on the manual on this site for the G90 is not helping me on this. Any help would be appreciated!
Phoenixed
Link Posted: Mon Jan 14, 2013 9:49 pm Post subject: |
Did you check your CLAMP settings in the service menu?
_________________ Planar PD-8150/Runco LS-5
Phoenixed
Link Posted: Mon Jan 14, 2013 9:59 pm Post subject: |
Also what leds are lit up?
