Sony g90 best possible performance
Keuka758
PostLink    Posted: Fri Feb 24, 2012 4:20 pm    Post subject: Sony g90 best possible performance Reply with quote
Hello,
I'm happy to have owned my Sony g90 for about 10 years now, and have not "monkeyed" much with it , except to keep it calibrated. Several years back we did add a moome single HDMI "in" card. This is used in conjunction with Classe Audio/B &W audio components and a Faroudja DVP 1010 scaler.
Dilemma:
Have recently auditioned jvc dla x3 and x7. Very impressed in many ways. One reviewer talked about using a Lumagen processor with the jvc, and that got me thinking,
1) would the lumagen be a meaningful upgrade over the Faroudja(and can a "homeowner" make it work)?
2) is the NEW moome card allowing higher resolution than the one I have?
3) what is the best combo (scaler/card, etc) to make the g90 its' best? Apart from stacking two of them.
4) would you rather have the g90 with the lumagen OR the jvc x7/x70 with the lumagen?
Many thanks!
PostLink    Posted: Fri Feb 24, 2012 4:23 pm    Post subject: Reply with quote
Welcome! I don't quite understand where the Faroudja fits into the signal chain. It can't process HDMI, so why are you using it or the Classe equipment in the video signal chain at all?
HDMI sources --> Lumagen--> Moome card would be the way to go.
TV/Projector: JVC RS45
PostLink    Posted: Fri Feb 24, 2012 4:29 pm    Post subject: Reply with quote
Welcome to the forum!
If you've had your G90 for 10 years, how's the tube condition looking?
In a general sense, you can definitely use the Lumagen to get significantly improved color calibration out of a G90. Gamma and greyscale would both be much better than without.
As for whether a casual user could do it himself... Yes, but only if he invested in a color meter and a significant amount of time learning about color calibration and learning about both the Lumagen and G90's controls. Considering the time investment, most people would be better-served to pay a pro to maximize the return on something as expensive as a Lumagen.
Cheers,
PostLink    Posted: Fri Feb 24, 2012 4:31 pm    Post subject: Reply with quote
Lumagen would be a huge upgrade just for the full CMS and Gamma and Greyscale adjustments at 21 points. Do it and use the money left over from the JVC you don't have to buy for new tubes and watch it for another 10 years.
PostLink    Posted: Fri Feb 24, 2012 4:37 pm    Post subject: Reply with quote
+1 to what Curt said.
Keep it digital the whole way like this:
Sources -> HDMI cables -> Lumagen -> HDMI cable -> Moome card in the G90
If you want to do video switching some other way for convenience sake you could throw in a preamp or receiver like this:
Sources -> HDMI cables -> preamp -> HDMI cable -> Lumagen -> HDMI cable -> Moome card in the G90
Many people do this and this is why the Radiance Mini exists. See: http://www.curtpalme.com/Radiance.shtm
The Lumagen, while also a scaler like your Faroudja, is considerably more than that. Those that buy it today are probably not buying it for the scaling but for everything else it does including parametric greyscale and gamma adjustment, image adjustment for anamorphic lenses (no use to CRT owners) / aspect ratio control, primary/secondary colour adjustment, automated calibration using ChromaPure software, 3D processing, noise reduction/detail enhancement, and so on.
Owners of high end CRT projectors like your G90 will also look to the Radiance "+" models to 1080p at 72Hz instead of 60Hz. This is exactly 3 times the refresh rate of film so you reduce all judder for the smoothest motion.
You should be running your G90 at 1080p (1920x1080). Don't worry about higher resolutions. There's no point. All of Moome's HDMI cards can do this including old and new. The newer ones give you better image quality as they use better (newer) components.
The G90 vs JVC LCOS projector is a hard one. Both have their strengths and weaknesses. Which is choose depends more on your personal needs, how much you value certain qualities over another. If your G90 is working well (tube condition is still reasonable), is installed and up on the ceiling, and you're happy with it, I'd say stick with it.
PostLink    Posted: Fri Feb 24, 2012 4:41 pm    Post subject: Reply with quote
Kal he can use the lumagen for switching and use the second output from the lumagen for audio to the classe. One input on the classe for video to make it easier. this way video is un touched to the lumagen.
PostLink    Posted: Fri Feb 24, 2012 4:52 pm    Post subject: Reply with quote
Good point. That's another option.
Not sure which Classe he has but their CT-SSP and SSP-800 have HDMI 1.4 switching available. The options are there possibly to have either the audio preamp or the Lumagen to do A/V switching. If the signal's kept digital the whole way which way you go doesn't matter. Do whatever's easiest.
I always liked Classe... probably because I lived in Montreal (where they're from) for 8+ years back in their heyday. I used to visit the local high end shops and drool on the power amps. Wink
PostLink    Posted: Fri Feb 24, 2012 5:06 pm    Post subject: Reply with quote
BTW, Keuka, post your location. If you need assistance, one of us here is probably close to you.
Keuka758
PostLink    Posted: Fri Feb 24, 2012 6:12 pm    Post subject: Reply with quote
Wow! Thank you all for such prompt and thoughtful responses! Someone came to the house shortly after I posted this- and when I came back, holy cow! For clarification:
1) to curt's question: cable box goes component to the DVP 1010, then component to the g90. I watch a lot of sports here( Syracuse junkie). Other sources go HDMI to the moome card
2) to ecrabb: tubes are very very low mileage, as I travel extensively and this is a secondary viewing room. Also, thanks for your explanation of the user friendliness of the Lumagen, I only asked because I live in the middle of nowhere in central NY so lumagen techs are about as rare as skyscrapers! By the way, I'm not into the Lumagen because I'm a color or grayscale wacko-- I'm more about resolution appearance and no motion garbage. Am I barking up the wrong tree by wanting the Lumagen (for either the g90 or the jvc x7)?
3) kal, so, should I get the new moome card since the image quality is better and it's not a lot of Money?
Thank you all, you've helped SO much!
JS
PostLink    Posted: Fri Feb 24, 2012 6:24 pm    Post subject: Reply with quote
Who you calling a whacko... Wink
Nope. Not the wrong tree. It'll give you the flexibility to do whatever you want. It's not much help with motion on the digital however as they'll just show whatever refresh rate you feed them (24hz for film content, 30 for video content). It's more for the CRT projector so that you can do film at equal multiples of 24hz (3x24 to be exact) to not have the source device or video processor have to do 3:2 pulldown to convert from 24 to 60Hz. 72Hz is only available on the Radiance XS+ and XE+, not the Radiance Mini. There's no "+" version of the Mini. For more info see the Radiance page here: http://www.curtpalme.com/Radiance.shtm
The newer the card the better. Will the difference be noticeable by you? Tough call. Some people notice the tiniest in improvements, others are hard pressed to see the difference between SD and HD and don't care. Moome's newest card (the one with HDMI 1.4) isn't shipping for another couple of weeks so it's anyone's guess as to how much "better" it is, especially since I don't know which version you have now. Technically it "looks" better on paper than previous cards (newer, higher bandwidth parts). You can wait and read some of the reviews first if you want. Of course, Moome's offering it up slightly cheaper when pre-ordering now. Wink
PostLink    Posted: Fri Feb 24, 2012 6:25 pm    Post subject: Reply with quote
Where is central NY? I live in the buffalo area. If i can get away, after you get the lumagen, I could come over with my Probes and Calman Professional and do a quick greyscale color calibration. Trust me after its done you will be a color grey scale junkie. The added depth a good calibration brings to CRT is amazing. It makes more of an impact than any other upgrade.
PostLink    Posted: Fri Feb 24, 2012 6:37 pm    Post subject: Reply with quote
That's a good point. The Lumagen greyscale/gamma/colour adjustment tools they provide are indeed just that: Tools. They're meant for someone who uses calibration software with a meter and wants to get as close to perfection as possible.
How much having the external Lumagen greyscale/gamma/colour adjustment tools helps depends on how lacking those tools are in the display. Many displays don't have all the controls to begin with or they're limited or broken. So having a Radiance really helps. Got a digital with lots of low level adjustments and a non-broken CMS? Then the Radiance won't help as much.
That said, there's an simpler approach availabe now too with ChromaPure auto-calibrate for those that don't really want ot learn/understand calibration. You hook up ChromaPure to the Lumagen and let it make the adjustments for you. All you have to do is hook it up and answer a few simple questions. It's fast (takes about 5 mins) and works well. Allows someone with zero calibration experience to get very close to perfect greyscale/gamma/colour on just about any display. (Assuming the display doesn't have undersaturated primaries to begin with as nothing software based can fix that).
The only downside to autocalibrate is that you need a video processor like the Lumagen Radiance which, purchased *just* for the calibration is pretty expensive for most people.
(Though we did just recently drop the price of the Radiance Mini and Radiance XS permanently...) Wink
Someone who wants to do this I'd recommend:
Radiance Mini: $1499
ChromaPure Standard + Display 3 Pro meter: $569
ChromaPure autocalibrate add-on: $139
TOTAL: $2207
So you see, it's not exactly an inexpensive solution for most people and getting a pro do come in and do calibration will be less.
Keep in mind though, that the pro will be using the controls in the display only to calibrate. That often means only 2-point adjustment for gamma and greyscale (instead of parametric multi-point), and many displays have no CMS at all or have a CMS that doesn't work right.
So to truly compare the price with what a pro does, you need to ignore the Radiance price somewhat. A pro can possibly get you much better calibration when you use a tool like the Radiance (assuming the pro knows what they're doing).
Look at the report that the pro provides at the end of the calibration too. Likely the results won't be 100% perfect but will be "as close as they can get" with the tools they have which are the controls in the display. Having the Radiance takes away a lot of that limitation. How much depends on the display and the limitations. CRT projectors all (including the G90) only have 2-point greyscale calibration and zero gamma adjustments so the Radiance can help out more than on some displays. It's usually easier to get flat greyscale with digitals.
jbmeyer13
PostLink    Posted: Mon Mar 12, 2012 4:55 pm    Post subject: Reply with quote
Kal- Will the Chroma Pure equipment work with a Lumagen HDQ or only the newer Radiance?
Projector: 9500LC- Dragan's HD Mods, ETECH PS Mods, Moome 1.3, HD10F's & a V1 case!
PostLink    Posted: Mon Mar 12, 2012 5:05 pm    Post subject: Reply with quote
The Lumagen HDQ does not have the controls available to do what's needed so it will not work for autocalibrate.
You need the Radiance. See: http://www.curtpalme.com/Radiance.shtm
