XG75 Power supply mod to 230 volt for Australia
PostLink    Posted: Thu Feb 09, 2012 12:29 pm    Post subject: XG75 Power supply mod to 230 volt for Australia Reply with quote
Actually for a Runco DTV991, but its got a 110 volt power supply, is there a way i can modify this to allow me to connect it to the 230 volt Australian mains supply?
HaydnG90
PostLink    Posted: Thu Feb 09, 2012 5:28 pm    Post subject: Reply with quote
Have you checked to see if there is a switch on the PS that allows you to toggle between the 2 power settings. Prob need to change the fuse too.
PostLink    Posted: Fri Feb 10, 2012 6:54 am    Post subject: Reply with quote
I havent got the projector here yet, but if there was a switch, i dont think the previous owner wouldve bought a step down tranny to use it.
Ive never heard of there being a switch though, but speculation is pointless.
PostLink    Posted: Fri Feb 10, 2012 7:43 am    Post subject: Reply with quote
Probably it can be converted, as all previous NECs had a jumper IN the powersuply which controlled the mains voltage range. Probably worth a look. Or we would need the schematics of the LVPS...
NEC 6PG xtra
PostLink    Posted: Sat Feb 11, 2012 6:42 am    Post subject: Reply with quote
Yeah would be awesome if someone can actually open one up and have a look, id love to be able to just plug it into 230 volt instead of stepping down.
nettwerkjohn
PostLink    Posted: Sat Feb 11, 2012 8:22 am    Post subject: Reply with quote
far as im aware, totally different power supply. terry chuchuf used to have a 230v supply...
PostLink    Posted: Sat Feb 11, 2012 8:50 am    Post subject: Reply with quote
I wont buy another supply, if it cant be converted ill just use a step down.
PostLink    Posted: Sat Feb 11, 2012 8:54 am    Post subject: Reply with quote
That step down transformer should be pretty enormous, if you get it please share a pic from it Wink
NEC 6PG xtra
PostLink    Posted: Sat Feb 11, 2012 9:30 am    Post subject: Reply with quote
2 kVA mate yeah. Will likely be shipped on Monday. Just purchased.
PostLink    Posted: Sun Feb 12, 2012 12:14 am    Post subject: Reply with quote
The primary sections of the 110v vs. 220v supplies are completely different. No switch, no jumpers. And the differences between them in the xx0 version is completely different in design. In the xx1 versions the design is similar but still greatly different in components.
macgyver566@gmail.com
PostLink    Posted: Sun Feb 12, 2012 3:37 am    Post subject: Reply with quote
Thanks Macgyver, this is the kind of straight forward close the book answer i was looking for Wink
Ive got the 2 kVA step down tranny on order anyway, so we'll be laughin when that turns up. Got abit of work to do before i fire it up anyway, will likely have to bleed the tubes and give it all a good internal clean ( although from the pics it looks to be very clean allready )
pasey25
PostLink    Posted: Fri Mar 16, 2012 12:34 pm    Post subject: Reply with quote
the 110v XG powersupply can be converted to 240v
mine has and has been running like this for 4-5 years. Before that I ran it off a 1KVA stepdown (i still have it, great doorstop)
Mark_A_W helped me with my conversion. I'm not sure if he still frequents these boards, but i have no recollection that far back anymore.
for reference mine was a XG-750 chassis. I believe the overriding principle for the change carried through to the xx1 chassis' though.
PostLink    Posted: Sat Mar 17, 2012 10:07 am    Post subject: Reply with quote
Yeah i thought he did, but it doesnt really matter at this point, i have a 2kVA 230 volt to 110 volt step down trans that i use for it.
I dont know if i really want to go to the trouble of pulling the power supply out of it to convert it to 230 volts now.
nunziom
PostLink    Posted: Fri Mar 30, 2012 12:07 pm    Post subject: Reply with quote
Great info here... I have had similar issues.
PostLink    Posted: Fri Mar 30, 2012 12:46 pm    Post subject: Reply with quote
What sort of projector do you have Nunziom?
