Marquee owners, check out these menus!
PostLink    Posted: Mon Feb 06, 2012 7:21 pm    Post subject: Marquee owners, check out these menus! Reply with quote
Check this out!
 Filesize:  141.73 KB
 Viewed:  641 Time(s)
 Filesize:  141.24 KB
 Viewed:  641 Time(s)
 Filesize:  154.81 KB
 Viewed:  641 Time(s)
 Filesize:  139.16 KB
 Viewed:  641 Time(s)
PostLink    Posted: Mon Feb 06, 2012 7:52 pm    Post subject: Reply with quote
Hmm , they must have started over with a new software version for the 9572 or it was a special custom OEM spec from a customer.
What does the chip say on the CLM?
PostLink    Posted: Mon Feb 06, 2012 7:55 pm    Post subject: Reply with quote
I have the Contrast modulation, and the Horizontal keystone I think but the the Green left, what ever that is.The Zone skew is kinda cool but probably only needed for a dome set up I bet.
HK-Steve
PostLink    Posted: Mon Feb 06, 2012 8:39 pm    Post subject: Reply with quote
Why does Curt have a date with Anna,
opps sorry, reading the wrong text !!!!!!!!!!!
Seems like some zone control, but, would be pretty funky to play with. then zero it after the picture gets all screwed up.
PostLink    Posted: Mon Feb 06, 2012 8:43 pm    Post subject: Reply with quote
Cause Anna loves me! Smile
This is out of a simulator 9500. Complete thick metal enclosure of the focus board they sent in as well. additional shielding on the CKM as well. Strange problems with this CLM- intermittent loss of the H direction of geometry. Power down, power up, and the H convergence and geometry is lost. Off and on again, and it comes back. Go figure. Cleaned all socketed chips and module connections, it hasn't done it since.
HK-Steve
PostLink    Posted: Mon Feb 06, 2012 9:00 pm    Post subject: Reply with quote
Opps,
Did you just say that out loud!!!!!!!!!! Anna loves me, ANNA LOVES ME, Yes you did..........
Strange with the CLM, normally contact problem, but is not pointing that direction.
Cheers
